1972 Big Block Swap
Here is a little background - 1972 Corvette Roadster with nonmatching #s 350 and a M20 4 speed. Car was frame off restored in 2008 locally.
Have scoured the net and these forums for assistance on this swap - now while this has been done numerous times, the questions I searched for had varying answers.
I am humbly posting this hopefully as an all inclusive (for my car) should someone wish to have detailed specifics on this type of swap on this year and model Corvette.
I am installing a 454 big block.
So far I have ordered the following new parts:
-Auto Gear M22Z 4 speed
-Stinger Fiberglass L88 hood
- Rear wheel bearings (not related to the swap)
-New radiator support BBC
-New radiator mout and sealing kit BBC
-New BBC accessory brackets (alt, power steering)
-New BBC power steering pulley
-New Centerforce DF clutch
Still a TON more to order but I can only spend so much in a week lol.
Here are some pics below of before the work and the start of the swap.
Help me understand ?
Will
Will
Anyone know where I can find a new chrome alt pulley?
Thanks again!
https://willcoxcorvette.com/corvette...r-pulley-66-72
Will
Before electric fan went in.
After fan and spreader bar. Look at all that room!
Or you could go with a March serpentine belt set up. Looks cool, way more reliable in the long run.
I went that route and then changed out the fan to electric so I could add a spreader bar in there as room will be at a premium in the front of the motor once you tuck that 454 in there.
Pictures of my set up.
For your chrome alternator pulley, you could try spacing out the alternator to line it up with the outer PS pulley. Here is an example of spacing out the alternator, but it still didn't quite line up like the correct pulley.
Wrong pulley:
Correct pulley:
https://www.corvettemods.com/C3-Corv...SABEgJP6PD_BwE
If you are thinking chrome I have no idea where to find that. Might need to to talk to a local motorcycle shop and see what kinda trouble you would be looking at.
Pics from Paragon
Pics from Paragon
I was hoping i could run aftermarket billet pulleys on the crank and water pump and be ok? I would think I should be assuming I make sure they are for a short water pump as the rest of my pulleys and brackets are for short water pump.
I did have billet pulleys on my SBC and had no issues - certainly cheaper than OEM
Good luck on the build.
