Power window question
I had to replace the drivers door last year before painting.The door I bought had manual windows mine are electric. After swapping the internal parts the window now wont go up without help. It`s a 74 coupe. I have replaced the motor the gear the rollers and the spring and it still acts the same. Is it possible to have the spring on backwards ? Is there a difference between the left and right side for the assist spring ?
here is a picture of a drivers side door with the outer skin removed
https://www.corvetteforum.com/forums...placement.html
