Headlight switch screw
Old Apr 26, 2019 | 09:08 PM
Ramirez1976's Avatar
Ramirez1976
Default Headlight switch screw
I've been having some trouble removing the old headlight switch nut, I know all I have to do it unscrew it, I just don't know with what I should do it with. Has anyone done this before?
It is the metal part on the inside of the plastic housing.
Old Apr 26, 2019 | 11:03 PM
Eliredandblack's Avatar
Eliredandblack
If you are speaking about the nut with two slots that hold the switch in place, there is a special wrench for it sold by Corvette vendors. After I messed up the electrical plug, and had no lights, I took a flat piece of thin metal and made a wrench with my trusty Dremel. I can send you a picture tomorrow if you need it. Basically, a flat piece of metal, then I cut out a “U” so the metal would only engage the outer shoulders. I don’t think the vendors had a picture of the wrench.
Old Apr 27, 2019 | 05:46 AM
7T1vette's Avatar
7T1vette
All you need to do is get it turning; then you can use your fingers to remove it. If you don't have the 'special' tool or some snap ring pliers to fit the slots, use the tips of needle-nosed pliers (pliers held in-line with the direction of switch movement) to give it a CCW twist. Just get the tips in the slots and give 1/4 turn or so twist to break it free.
Old Apr 27, 2019 | 09:19 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I had that special tool and cant find it. I needed it this week so I used the flat blade like end of one of my short pry bars. It was wide enough to act as a flat head screwdriver although it had that angle on the end so it was a bit of a challenge
Old Apr 28, 2019 | 08:48 AM
kansas123's Avatar
kansas123
I used and old wood chisel........worked good for me
Old Apr 28, 2019 | 09:41 AM
Mooser's Avatar
Mooser
Cheap cheap cheap (dollar store type) 7/16" (I think it was, have to check) deep socket and a few minutes on the bench grinder = special tool #17
M
To Headlight switch screw
