Starting a cold engine
Old May 18, 2019 | 09:43 AM
pltmgr's Avatar
pltmgr
Originally Posted by firstgenaddict
With nearly any stock engine equipped with a Holley and Auto divorced choke - this is what I have done for 20+ years.
If it has been sitting a couple of weeks I pull of the aircleaner lid and fill the holley bowls through the vents with a squeeze bottle. then a quick squirt into the primary throttle bores.. fires right up immediately.
If it's a restart after recent drive - just hit the key.
Engine cold overnight. once to the floor to set the fast idle/choke. -
Less than a couple of weeks- three times and hit the key.
Over the years I found that each vehicle may have its own "personality" but the above is generally what I do.
