[QUOTE=PainfullySlow;1599449624]Will do for sure. I have to make sure that the trans fits the modified crossmember anyway which will happen well before I fire up anything. I will be sure to post up a video!
If you have any fitment issues, look at G Force Cross members.
I picked one up for my 73 because I want to run 3" exhaust all the way back, which would not fit through the stock one.
Nice piece and you won't have to powder coat it!
Thanks OCB! I modified my original xmember but if it does not work out I will absolutely check out the G Force site.
In other news, I happened across a cheap ($~15) oil press, volt, and water temp gauge set at harbor freight of all places. Those should serve well enough for a quick fire-up.
