Radiator core support BBC/SBC
Presumably these panels are there to funnel air to the smaller SBC radiator.
If I swap out to a Griffin Radiator, I take it I can remove these panels, yes ?
Overall Width (in):32.000 in.
Overall Height (in):18.480 in.
Overall Thickness (in):3.000 in.
Core Width (in):27.500 in.
Core Height (in):18.480 in.
The support with the block off plates (and the one in rzvio's post), is the support used with the 19" aluminum radiator. I think removing the plates from the 19" support will result in a 26" opening, not the 27" opening that would match the 27" Griffin. Whether the opening is 26" or 27" after removing the plates, if the Griffin is designed to be a replacement for the 27" big block radiator, the way it mounts will still be different than the mounts in your 19" radiator support.
I'm not real familiar with the Griffin radiator, but based on the dimensions of the Griffin (27 1/2" wide core), I assume that it mounts by sitting in saddles, and requires a 69-72 big block core support.
