81 cel
Old May 21, 2019 | 02:26 PM
66ca's Avatar
66ca
Default 81 cel
I’ve done a few things to my 81 and now the CEL is on and was wondering the best way to get it off?
i live in north Texas and we don’t require and smog testing or anything like that.
The catalytic converter has already been removed, some smog stuff removed, a new HEI distributor installed, and Lars is rebuilding me a replacement carb right now.
I just want to get rid of the light, and wondered what’s the easiest way
Old May 21, 2019 | 03:34 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If you're still running the computer, have you checked it for an error code?
Old May 21, 2019 | 03:38 PM
66ca's Avatar
66ca
I was told when I swapped out the distributor that the light would come on. And it did.
I just need to know how to get the light off
Old May 21, 2019 | 04:07 PM
Bikespace's Avatar
Bikespace
Reach up behind the dash and pull the bulb? It is in a 1/4 turn twist-lock socket that will come out completely (no wires). Easy to replace, too.
Old May 21, 2019 | 04:09 PM
66ca's Avatar
66ca
Do you have to take the gauge cluster out to get to the bulb?
Old May 21, 2019 | 04:13 PM
Bikespace's Avatar
Bikespace
Not in my car, but I don't have a radio or an HVAC system. Look for a picture so you know what to feel for. The dash bulb sockets are the same, and you can get to some of those.
Old May 21, 2019 | 09:39 PM
7T1vette's Avatar
7T1vette
If the CAT and CCC system components have been removed, there is no need from the CEL to work. Remove the bulb, as mentioned.
Old May 22, 2019 | 08:52 AM
derekderek's Avatar
derekderek
Screw the bulb. Remove the computer. Right by battery.
Old May 22, 2019 | 09:06 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Simply unplug it and remove it. On the off chance you ever want to go back and reinstall, all you have to do is plug it back in.
Old May 24, 2019 | 03:59 AM
ramair_bryan's Avatar
ramair_bryan
Easiest way to ditch the lite....
Stick that little smiley face decal over the lens so when you look at it, you just smile cause get'n rid of that CCC was the best thing you ever did...…………..
God bless texas.
God help us in calif.
Old May 24, 2019 | 04:18 AM
66ca's Avatar
66ca
Hahahaha!!!
i got an email from Lars and he is about to send my carb back to me, so once I get it on I’ll remove the computer and the rest of the smog stuff.
Im hoping by removing the computer it’ll turn the light off.
Old May 24, 2019 | 06:03 AM
derekderek's Avatar
derekderek
the ecm is what is turning the light ON, so confidence is high...
To 81 cel
