Spiral insert volume
Old May 24, 2019 | 12:36 PM
Tom_K's Avatar
Tom_K
Default Spiral insert volume
I have order a set of the spiral baffle side pipe inserts. I am concerned about the sound still being too loud
has anyone with these tried putting cone inserts into collectors to further reduce sound level?
https://www.summitracing.com/parts/s...SABEgLXCfD_BwE
Old May 24, 2019 | 05:17 PM
bazza77's Avatar
bazza77
Yes I have them .
I put the 3 and 1/2 inch ones in .
What I have is the 2 and 1/2 inch sweet thunder inserts in the hooker side pipe.At the beginning and end of the sweet thunder insert the tube cones out to 4 inch to fit snug in the pipe. On the inlet cone I drilled 3 holes and welded 3 nuts on the out side of the cone . Using spacers between the perforated cone and the S.T inserts. ( I was worried about back pressure ) They sit just clear of a sealed fit.
They do make a noticeable difference.
Old May 24, 2019 | 09:54 PM
lars's Avatar
lars
I have Spiral Baffles, and I even drilled a 5/8" hole through the center caps. With the holes and the stock baffles, I can talk to the person next to me while driving with the top down. Sounds real nice, but I wouldn't want to be the lady in the convertible Mercedes next to me at a stop light trying to talk on her cell phone...
Lars
Old May 26, 2019 | 11:05 AM
REELAV8R's Avatar
REELAV8R
I have a 1” hole in place of the stock caps. Running 10.6:1 compression ( more compression makes the sound sharper and louder) and still find the volume suitable for cruising. At least until I tromp on it then yes it’s loud.
if you leave or put Caps on ( I’ve read they no longer come with caps) then it reduces the volume considerably. Anything that reduces the volume reduces the flow and thereby the HP potential to WOT high RPM. So it’s a trade off.
To Spiral insert volume
