81 Corvette poor idle
Old May 25, 2019 | 07:12 PM
Tim81's Avatar
Tim81
Default 81 Corvette poor idle
This is a completely refurbished carburetor that runs great but has a very rough idle. The Carb is set to factory specs and the computer is not pulling any codes. The Dwell is floating right around 30 degrees. One thing I noticed is when adjusting the mixture screws the screw on the driver side does not have any effect on the idle. I can screw it all the way in and nothing changes. Any thoughts would be greatly appreciated.
Old May 26, 2019 | 02:02 AM
Antz81's Avatar
Antz81
Have you checked to make sure your timing is correct? is the timing mark on your balancer still in the correct position? As Lars would say, "90% of carb problems are in the distributor"
Do you know when your timing chain was last checked?
Old May 26, 2019 | 07:59 AM
Tim81's Avatar
Tim81
The timing is set to where I get the best idle, the chain was replaced two years ago. The car had this problem since I have owned it 10+ years.
Old May 27, 2019 | 10:41 AM
MelWff's Avatar
MelWff
the fact that the mixture screw has no effect points to the carburetor only. You have a problem with the rebuilder, possibly a blocked passage, contact them
Old May 27, 2019 | 11:30 AM
7T1vette's Avatar
7T1vette
What he said....
Old May 27, 2019 | 06:53 PM
Tim81's Avatar
Tim81
Thanks Gents, I rebuilt the carb so no one to blame but myself. I just ordered a professionally rebuilt carb, hopefully it will work.
Old May 28, 2019 | 07:22 PM
lars's Avatar
lars
Be aware that "professionally rebuilt" carbs are assembly-line jobs done by 3rd-graders in Mexico... don't get your hopes up on a commercially rebuilt carb.
Lars
Old May 30, 2019 | 05:26 PM
Tim81's Avatar
Tim81
Lars, can you recommend someone who rebuilds e4me carburetors.
Old May 30, 2019 | 05:39 PM
derekderek's Avatar
derekderek
This guy named Lars is pretty good. But I feel all 81 electronic controlled carbs should be taken down to the river and float tested.
Old May 30, 2019 | 06:43 PM
fake's Avatar
fake
Check or replace your vacumn hoses might be a quick fit. Try Doctor Rebuild out of Bridgeport Ct he sells all the hoses by the set and has nothing but quality pieces!
To 81 Corvette poor idle
