Tire size help!
Old Jun 2, 2019 | 04:11 PM
L82 crusin's Avatar
L82 crusin
Default Tire size help!
Hi,
Just wondeirng if i would be able to run a 235/40 with an 18x8.5 wheel set up on a 75' without any rubbing iisues?
Thanks!
Old Jun 2, 2019 | 06:39 PM
MelWff's Avatar
MelWff
that tire is only 25.4 inches in diameter, stock tire is 27" why are you trying to install such a small tire?
Old Jun 2, 2019 | 08:05 PM
L82 crusin's Avatar
L82 crusin
i do plan on lowering the car a bit and didnt want to have rubbing issues. if i plan on dropping about half an inch in the front and about an inch and a half - two
in the rear you think i could go bigger?
Old Jun 3, 2019 | 01:18 PM
MelWff's Avatar
MelWff
are you lowering the car just for looks or for better handling since installing 235 tires defeats any handling improvement.
To Tire size help!
