Convert gauges to can bus display
Has anyone done this in here? Just starting to do research. Looking for suggestions on good software and displays.
-Stroke
-Stroke
I think AEM has a canbus display and canbus sensors although I dont have experience with them.
I did a complete diy canbus display (and body module and transmission controller) in my project.
I really like what you did with the arduino. I’ve looked into doing just a simple gauge readout with raspberry pi but even though it’s supposed to be really simple, all that stuff just seems like I’d be in over my head and not be able to make it what I want. I’ve never done any programming. FAST makes a system, although, not sure of its full capabilities.
The thing I like about the AEM display is that their canbus is not proprietary. They publish a list of all the CAN messages. That means that you can use their sensors or build any of your own to talk to their display. This is probably a benefit to a very small number of users.
What engine and engine management are you thinking about connecting to?
Bikespace (06-05-2019)
Why? What would that get you??? If your gauges are not working properly, it would be much less trouble and expense to just the them in working order again. They are relatively simple instruments that do exactly what is needed for monitoring your engine and electrical system.
Received 1,126 Likes
https://www.corvetteforum.com/forums...rip-car-3.html
Thanks again. I may reach out for some more advice to you soon if you are willing.
-Stroke
Plus, displays are dope, yo.
-Stroke
If monitoring more parameters gets you the info you need, OK. And, doing everything with digital information (then converting that to analog 'appearing' gauges) is definitely more flexible. I guess I'm just wondering if this effort is more for the 'pizzazz' of doing it than it is for gaining useful information. And that is OK, if that's your goal. Maybe I'm too pragmatic....
As far as digital gauge displays go, I'm all for them. But, I've not seen any that are really user friendly with simple selection of gauge designs, scaling, fonts, colors, parameter type, location, etc., etc. If there is such an item available, I want one for the dash of the hybrid-electric vehicle I'm building. It has a LOT of parameters I need to monitor...and few of them have anything to do with an internal combustion engine.
Received 3,220 Likes
Yep- otherwise everyone we'd all be driving a Prius!!!!
Here's a great write up-
https://www.instructables.com/id/Veh...Gauge-Display/
Strokemyaxe (06-06-2019)
-Stroke
There are multi purpose intelligent digital displays that let you more easily control fonts, locations, gauges. buttons, progress bars, etc. I use one from Nextion. saves a ton of work. Some of the Nextion ones also have a processor built in that you can program for limited functionality and inputs.
But you need some processor that interfaces all the sensor info with the display. That's what I did. My display not only shows what's going on, it shows the more important stuff relevant to each mode of operation and it actually allows me (touch screen) to change the way the car is operating in hundreds of ways without having to drag out the laptop. One click of the screen and now my shift points and boost targets, cooling have changed from cruise to sport mode. Another click and it's in burnout mode where all the shift strategies change, rules and operating parameters change as well as the font sizes and gauges. Another click and now it follows the rules for launching at the drag strip. Another click and it's set up for the dyno. Another click and it shows me how all the pwms for the fans and fuel pumps and transmission are running. It's all custom, but my goal was to have a car that does lots of things well.
The stuff I need is already in hand or well planned. The only item that hasn't been defined is the dash display. A panel display with software that could offer variety of gauge parameter could be useful for ALL custom vehicle builds. I just am baffled that someone hasn't done it yet.
-Stroke
I have no idea what's what in this world of displays but I have run across these while looking for other stuff
https://www.pegasusautoracing.com/ke...t=dash+display
Any progress on the displays?
Got a brainstorm. I was just thinking that there are off the shelf displays with gauges that read canbus, and very inexpensive I might add. Except there is one caveat. They display upside down and backwards and are used to create a heads up display.
https://www.ebay.com/itm/W02-HUD-Hea...8AAOSwqspcnOi7
I'm thinking of adding a Heads Up Display (HUD) like this to my car, but that would be just a gee whiz gimmic.
In my C3 Vette, the display isn't only to get information, but to control the car. My display is a touch screen and can let me change driving modes, shifting modes, hundreds of parameters including boost per gear in each driving mode, shift points for each gear and driving mode, shift firmness, lockup or no lockup, paddle shifting or automatic, 6 PWM fan settings, PWM fuel pumps, alternator voltage and so on.
It's a fully integrated and customized. Designed to let the car be good at cruising, enthusiastic driving as well as drag racing. Each driving mode has a custom screen, different fonts and information to make it more useful for that mode. For example, when I'm drag racing, i don't want the transmission to shift into overdrive or lock up. Also I want to see bigger fonts and less info, just what's important for that 10 seconds.
Here's a cruise mode screen.
Drag mode screen:
There are currently 8 screens for different purposes. Touch screen lets you navigate from screen to screen and operate any buttons or hot spots.
Now that I'm driving the vette, I find myself changing the features, fonts and layouts. That's probably going to be an ongoing process.
Drag mode screen:
Nice. But I'm a hybrid-type guy....I want analog looking gauges on a digital screen. It's much easier to 'eyeball' an analog gauge to assess that parameter than to convert digits into a meaningful assessment. Can you train yourself to deal with digits? Sure. But I'm too damn old to convert!!
No. I want to buy one instrument...a digital screen....and pack lots of meaningful gauges onto several screens, serving different purposes---rather than to have a huge dashboard with lots of $100 gauges on it. Hmmmm.....
