Window switch question
Old Jun 6, 2019 | 12:36 PM
croaker's Avatar
croaker
Default Window switch question
What’s the reason for the longer leg? Clocking?
Old Jun 7, 2019 | 03:43 PM
SwampeastMike's Avatar
SwampeastMike
Just a guess but since I'm pretty sure that's the common terminal it might be a spot for a single conductor connector leading to a secondary switch. Cars very often have a master window control on the driver door with secondary ones on the others. That would allow the same switch to be used in both applications.
Old Jun 7, 2019 | 04:25 PM
7T1vette's Avatar
7T1vette
No idea. It could be intentional or it could be a manufacturing defect (as I suspect). If the connector will not engage with it properly, cut it to the length required to function properly.
Old Jun 7, 2019 | 04:46 PM
bradleyb66's Avatar
bradleyb66
My 79 switch is the same way - I assumed that something inside the wiring connector used that groove to prevent it from pulling out?
Old Jun 8, 2019 | 12:28 PM
7T1vette's Avatar
7T1vette
The A.I.M. for your model year would depict how it should be from the factory.
To Window switch question
