Another side pipe insert thread!
Old Jun 14, 2019 | 12:06 AM
htown81vette's Avatar
htown81vette
Originally Posted by gotgame
are yours capped? I just picked up a set two weeks ago and installed some freeze plugs ( hammered in plus 1 bolt just incase) over the center pipe and honestly i was really expecting it to be louder based on comments. Not bad at all. Even good when cruising in overdrive. People might think im crazy but at cruising speed in OD its not much louder then my dougs reverse flow. It is louder at idle and WOT but not obnoxious or anything.
I plan on leaving mine as is. For my engine I dont think ill get much better performance taking the caps off and my wife is fine with the sound.
I believe they are capped but I'd have to check to be sure.
Old Jun 14, 2019 | 12:11 AM
htown81vette
Originally Posted by bluegtp
I have classic chambered vette packs. They are not quiet but sound great. I will say they're much louder and meaner sounding at wot. I wouldn't mind them a little quieter but wouldn't want to trade the sound for something slightly less loud. Not too bad with windows up on the interstate and I can still hold a conversation with passenger.
I just moved into a newer subdivision and haven't had the neighbors complain yet.
383 stroker build (10.5:1 cr)
https://www.youtube.com/watch?v=u74LS8fbmnU&app=desktop
How did you like going from a 383 to the LS motor? Thinking about selling my 383 and going LS3 but just curious to hear from someone who has done it.
Old Jun 15, 2019 | 06:09 PM
76strokervette's Avatar
76strokervette
Video of 3 inch inserts
Old Jun 15, 2019 | 06:24 PM
74_stingray's Avatar
74_stingray
C3 of Year Finalist (performance mods) 2019
St. Jude Donor '19
Thanks for the video
Eddy
Old Jun 15, 2019 | 06:44 PM
80vette21's Avatar
80vette21
Originally Posted by 76strokervette
Which inserts?
Old Jun 15, 2019 | 06:56 PM
76strokervette
Classic chambered 3 inch inserts. Only revved to about 3000 rpm due to camera woman looking like she wanted to run out of the garage.
Old Jun 15, 2019 | 07:01 PM
80vette21's Avatar
80vette21
Haha nice. Chambered inserts or louvered?
Old Jun 15, 2019 | 07:07 PM
76strokervette
These are the louvered inserts with fiberglass wrap,
Old Jun 15, 2019 | 07:27 PM
80vette21's Avatar
80vette21
Oh boy haha. Can't wait to hear mine! Definitely a little louder than the 2.25" Sweet Thunders! The 3" will be good though. I drove it around with the straight side pipes and could really tell how much the 2.25 has been choking it out.
Old Jun 15, 2019 | 07:37 PM
76strokervette
There is an echo effect from being in the garage and I think they will be a little quieter outside.
But they are loud. When I talked to Eric he said anything 500 hp or higher will be choked by any insert
smaller than the 3 inch. FWIW they sound meaner in person.
Old Jun 15, 2019 | 08:43 PM
Chambered's Avatar
Chambered
Well, you'll lose some higher RPM performance with say 2.5"flowpath vs. 3", but 2.5" will not "kill" performance like the OE chambered sidepipes of the C2 era. Those had 1-5/8" cores. 2.5" is a great compromise if you want good street performance plus decent noise control.
Old Jun 15, 2019 | 08:54 PM
80vette21's Avatar
80vette21
Is 2.25" a significant difference from 2.5"? But yeah, the hooker glasspack inserts that came with my pipes were awful. I think they were 1 5/8
Old Jun 15, 2019 | 10:05 PM
  #33
Chambered's Avatar
Chambered
There's not a huge difference in flow between 2.25" & 2.5", & I don't think there is a significant decibel difference. Going from 2" flowpath to 2.25" & 2.5", there is a big difference in flow. Going from 2.5" to 3" there is a quantum leap in flow.
Old Jun 18, 2019 | 09:30 PM
  #34
bluegtp's Avatar
bluegtp
I like it. Gas mileage is much better with the 4l70 swap too. I also added aftermarket ac so it feels like a different car. Power is different though. Lots more top end, torque feels nice too. I have a pretty high stall in this one.
Old Jun 20, 2019 | 03:15 PM
  #35
titanle's Avatar
titanle
is there a big difference in sound between the 2.5" and 3" vettepack inserts?>
Old Jun 20, 2019 | 04:19 PM
  #36
Tom_K's Avatar
Tom_K
My first attempt:
This was just too loud
The header wrap worked great the pipes never got hot enough to burn.
Second attempt:
Spiral baffles with easy to remove center plugs.
These are quieter than the glass pack idea but still loud. I have not removed the center plugs and fired it up yet.
Baffle plug secured with cap screw through threaded bolt
Looking in end of sidepipe. Plug will be easy to remove or reinstall
Old Jun 20, 2019 | 04:34 PM
  #37
titanle's Avatar
titanle
That’s a really neat idea to wrap the insert with header wrap and then insert it into the side pipe itself. I may try that as well, maybe I won’t have to buy heat shields
To Another side pipe insert thread!
Old Jun 20, 2019 | 04:42 PM
  #38
Tom_K's Avatar
Tom_K
It really works well. The temp was less than others with heat shields, a lot less.
I wrapped them completely then did extra thick wraps and each end so the insert was a real tight fit into the pipe.
There was no need for any sort of attachments or screws from the insert to the side pipe.
Old Jun 20, 2019 | 04:53 PM
  #39
titanle's Avatar
titanle
You may have just saved me $300! I should send you a case of beer lol. I’m planning on getting the vettepack 2.5” inserts.
Old Jun 26, 2019 | 07:51 PM
  #40
zigvs's Avatar
zigvs
wait.You just took a set of regular glasspacks and welded reducers on the end to fit the 4" pipe?
