Renegade install tips/tricks ??
We've followed the install instructions to the letter but he dist is binding on the last 1/4" on the beveled part of the shaft.
We took precise measurements and the hole in the intake seems the same size as the OEM hole but visually the renegade hole looks SLIGHTLY off center.
Rather solve than return it.
ALSO, the EGR plate and air cleaner stud holes are too shallow to allow the OEM bolts to seat all the way in.........................
Dean
Notice how your dist has two machined bands near bottom?
And those bands fit (with a little play) into two machined holes in block; effectively "sealing" an oil galley.
If the intake's dist hole is offset too much, that might prevent the dist's bands from aligning with the block's holes; preventing dist from dropping into position.
Maybe?
Dean
I think we on our end, need to take a very serious look at maybe removing our tooling from the company and end it. If we do, it may never be manufactured again unless we can have the Arizona foundry that we first used here were to reduce their pouring cost and then that may work, maybe? Our machinist here is very good at machining the manifold and would never let a manifold go out of his shop knowing it was bad or even questionable for that matter in any way. I hope Dean can figure out what the issue is and if not machined correctly to get either a refund or exchange. The manifold does work nicely when done properly, the facts speak for themselves on that.
BTW, we did NOT set the price either. In the beginning, it was much cheaper at $460.95 when we were doing it which was only slightly more than the XRam manifold and we were pouring a complete manifold, not just using a Weiend four barrel manifold and making a top box mounted to it. The Renegade out performs the XRam hands down. Also, in the beginning, I saw one go on eBay for $700 that was serial number thirty something. I personally hand stamped each manifold, they do not do that anymore.
I just gratefull Tom and Crew poured the time and energy into fixing the most glaring handicap of our XFire cars !!
Suggest company or companies responsible for marketing it should quickly & transparently get handle on failure modes & root causes ...
... maybe it's consumer, maybe producer, maybe both.
Dean
Now, a PO had a dealership install the ZZ4 under that stock intake and injectors, and the CF member i bought it from had ported the intake -- but it just ran out of grunt around 4K RPM. Now the 700r4 masked that pretty well with its ODs but it couldn't reach redline, nor would it spin the tires.
NOW even a moderate launch spins them and it revs VERY fast -- feels like all 355hp is now there instead of more like a stock L83 mill
OH, and my installation tip/trick is to align the dizzy before torquing the inner intake bolts................................... ...
Happy days
RECOGNIZING that he is probably THE AUTHORITY on this subject. I know the history and all the BEGATS.
WHAT A STAND-UP GUY! Glad you're around...truly.
Unkahal.
ps too bad they don't let you hit the 'like button' 86 times! lol
