I have been restoring a 1968 and rebuild the differential, it is all put back together but had the car sitting on stands for a long period of time to do work now that the car is back on the ground appears the Differential is locked up and will not turn. I have had this car rolling in the past so I am baffled. I have disconnected the driveshaft to make sure its not the tranny still locked. Any Ideas?
how do you know the ebrake shoes arent the problem?
did you release all tension on the cable adjustment under the car?
did the remove the wheels and can see the lever the cable attaches to is fully released?
As stated above..I am going with the aftermarket Wilwood Parking brake caliper and Its not installed yet..removed the original e brake system so there is no Ebrake..I have 1" of movement and hear a "clunk" sound..Feels like something is binding but on exterior is all clear...What could loosen up inside after all this time to cause? or any other options..Just dont want to pull the diff if I don have to ..
There was a similar thread on here not long ago , it turned out to be the wheels he put on the car had lead balance weights that sat too high and got caught on the brake caliper .
As mentioned, isolate the diff- disconnect the 1/2 shafts and turn the driveshaft with the trans in neutral. It should spin without binding. If I still binds up you have to remove the diff. DId you rebuild it or have someone do it? If you did then you would know how it was put together and it sure wouldn't be binding up. Just sitting with residual oil on the bearings and gears should not cause anything to bind, if you had someone rebuild it and just installed it then all bets are off. I can show you some very interesting pictures of "rebuilt" diff's I have had to correct. The good news is you didn't power it up and break it. It might be something simple like a Ring gear bolt but you better find out.
