I’ve been doing a little searching and reading today and wondering if I’m missing something on mine.
On mine there is like a 3” gap between the radiator and condensor. You can see down from the top support between the 2. Is there something supposed to be there to help seal it off?
it seems like some of the things I’ve been reading have said air just blows around the condenser and doesn’t get sucked through by the fan if this is all open. Is this true or am I misunderstanding what I read? If it’s supposed to be, can someone give me some info on how to fix this. Pictures maybe.
Im also wondering if my fan clutch is any good. It seems to free spin a little too easy.
Has anyone switched from the 5 blade to the 7 blade and seen any improvement?
If you have the stock thermostatic fan, the clutch unit must be good or it won't cool, no matter how many blades are on the fan. To check the clutch action, get your car warmed up completely, so that the thermo clutch should be in operating mode. Stop car, open hood, and watch the fan action as you turn off the ignition. If the fan stops rotating after just 2-3 rotations, the clutch is operating as it should. If it just keeps spinning, the clutch is no good....or it's not hot enough for it to work. Either way, at that time, it is doing little to draw cool air through the radiator.
