Obd1/2 scanner
Old Jul 17, 2019 | 10:20 PM
Tkmoore1026's Avatar
Tkmoore1026
3rd Gear
Default Obd1/2 scanner
Is the a scanner that I can use for my 82 crossfire injection and my newer obdII cars? Prefer not to use the laptop and cable.
Old Jul 17, 2019 | 11:05 PM
68blvert's Avatar
68blvert
autozone, advance auto, oriely's, etc all sell lower line scanners that will do both. mostly generic data stream and code reading but will help with diag.
Old Jul 18, 2019 | 12:39 AM
Tkmoore1026
3rd Gear
I would like one that will display the tps voltage and other information. I was hoping someone would have a specific model they use.
Old Jul 18, 2019 | 01:17 AM
68blvert's Avatar
68blvert
If the scanner claims to read data then yes, it will more than likely show tps since tps is class 1 pid. Different scanners have different update rates and data stream speeds. If I were you I would research and compare scanners in the price range your shopping in. If you knew how much I've spent on diag equipment over the last 30 years you'd faint. There's a snap-on dealer somewhere I bought a boat for. Lol
Old Jul 18, 2019 | 01:26 AM
Tkmoore1026
3rd Gear
thanks for the info.
Old Jul 18, 2019 | 08:34 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
This is something like what you maybe looking for. Has the ability to read live data. I have an older version and there is more than enough live data displayed.
https://www.innova.com/en-US/Product...54525293470531
Old Jul 18, 2019 | 08:46 AM
Kacyc3's Avatar
Kacyc3
Watch swap meets, pawn shops, and fb market place you maybe able to find a good deal on a Snap on mt2500 "red brick" you will need the cables, adapter,keys, chips for GM OBD1 and OBD2.. THe good thing is you can buy specific chips say for you obd1 and then one for your 2015 GM and not have to pay for everything inbetween. If you are in a hurry you can buy them on ebay but it can get expensive fast. $100 for the scanner, $20 cable, $20 adapter, $30-50 for chips. I found two at a swap meet with cables, chips, adapters..yadda ,yadda for $50 combined.. I snatched them up took what I needed/wanted out of them for mine then after seeing prices on ebay sold each one for $100 with a cable, some chips, some adapters, a case.
Old Jul 18, 2019 | 09:12 AM
augiedoggy's Avatar
augiedoggy
I have no idea if it works on vehicles as old as 82 but I use an $8 ELM327 for all my other vehicles which blows away my actual old school obd scanner as far as features and functionality.. it uses a free app on my android phone called "torque" to view info and reset codes and such.. the one I have works via bluetooth but they make them for any interface including usb and such for pretty much any device. much easier than a laptop setup.
Old Jul 18, 2019 | 04:23 PM
fazang's Avatar
fazang
Hi, this link if accurate seems to show in detail the differences with pics.
http://www.neilkline.com/Tech%20Tips/obdcodes.htm
I would say you will have a tough time finding a scanner that does both 1982 and 1996+ cars.
If you do i expect you will need VERY deep pockets.
-ALF out...
Old Jul 18, 2019 | 04:57 PM
derekderek's Avatar
derekderek
ELM 327 and torgue or other similar phone apps are OBD 2. 96-up.
To Obd1/2 scanner
