intermittent start failure
Do your lights work when this happens? Mine still did (nothing else did, though).
I've poured over the 80 wiring diagram, and I still can't find any "Ignition Interrupt Relay", or something else that could make that ignition switch intermittent. I'd think a corroded terminal would cause a voltage drop, not an on/off, good/fail condition that can be reset with a battery power cycle. A corroded connector, or bad switch, could absolutely make a relay-fed system intermittent, though.
I'll keep looking.
I too have been looking through the circuits tracking down what should work with the key on even if the engine isn't running. I'll just check each item out if it happens again. Also, I always carry jumpers in the the car - not, real heavy gage jumpers, cost $30 in 1981 - not booster cables. If it happens again I plan connect on end to the bat negative and the other end of the same cable to a good ground and see if it then starts. That should answer the question on whether the issue is the battery negative cable ground or not.
You've talked about the negative ground to the frame is a short cable and you have cleaned and tightened it securely. What about the negative ground cable that goes from the frame to the the engine block? Have you checked the condition of that cable? I'm sorry if I have missed that in this thread but I just thought I would ask.
Hang in their Im sure a solution will come with all of the knowable people on this board.
it does Not have the R terminal for OE points distributors ... otherwise superior to just about all else ... OE for later model iron 350 motors 168T
PMGR permanent magnet gear reduction ... light small Very powerful & reliable ... $50 delivered
If you don't have points, you don't need R terminal anyway
This starter DOES HAVE the R terminal for OE points distributors ... otherwise superior to just about all else ... OE for later model iron 350 motors 168T / Mercruiser
PMGR permanent magnet gear reduction ... light small Very powerful & reliable ... $52 delivered
I'm having a similar issue but my acc is fine. I get the click, starter turns over, click starter turns over like my battery is low. Yesterday I put my charger on the battery for a few hours and then tried to start but got the same thing. Eventually it will start. My battery and alternator are good. Alternator is putting out around 14.5 volts. What I'm going to look at first is my solenoid connections. If they are tight and look good I'm going to pull the solenoid and see if anything is wrong with the return spring or internally. I might just change it out anyway as they are cheap.
To check this I moved the cable around and the lights would go on and off. I took the post style connector off and found a good deal of corrosion in on the old button connector. I cleaned that up, put it back together with the post connector, and put the cable back on the battery. It was now stable. The car started. I took it over for new tires and brought it home - 6 starts overall. All worked.
I'll give kudos on this to mrvette who rightfully pointed out that ohm meters are generally useless for high current connections. But, I generally don't have a good micro-ohm meter at home. This high current connections typically have only a couple milliohm interface resistance maximum. A contact with up to 50 milliohms might read 0 on and ohm meter. That might not be an issue with 5 or 10 amps, but given what little metal to metal contact there there is at 50 milliohms,if you hit it with 300 amps the metal that is trying to carry the current will just melt and oxidize.
What I'd like to find now is some good contact grease which has nickel filings in it. The company I work for and others typically put this on most of the high power utility connectors they sell as the nickel is corrosion resistant and, being very hard, will scrape through any corrosion which might be on the contact surfaces. Unfortunately the grease is not something we sell and all the connectors are made in Canada, so I can't walk out to the plant and get some. If anyone knows of one, please let me know.
... foremost because the relatively short Integrated Side-Post bolts didn't engage enough female threads within Side-Post batteries ...
... and would begin to strip out ... could not tighten enough before they began to strip ... I found a "long-term" remedy ...
... I use a clean "normal" threaded hex Bolt with clean nut ... bolt threaded deeper into battery's Side-Post until it stops firmly ...
... then, while holding bolt with one wrench, I tighten nut firmly against Side-Post cable with another wrench ...
--- a double-nutted stud with a third nut would also work as well ...
... also, I use normal dielectric grease throughout ... Never an issue since using this combo ... yes it looks bubba-fugly, but it works.
I use dielectric grease to prevent corrosion ... if the mechanical bond is tight enough, dielectric grease does not interfere.
I also pack some multi-pin connectors (e.g. trailer-lights, mowers & tractors) with dieletric grease ...
... monkey see-monkey do ... I learned that studying assembly line and PPAP, FMEA docs at now-shuttered Mack Truck Winnsboro SC campus.
Some greases are conductive ... that plus moisture can promote corrosion on batt terminal ... and on multi-pins, I don't want cross-tracking.
Until I learned there was such a thing as dielectric grease ... I had used any ol' grease.
I prefer dielectric grease ... but no grease or any ol' grease ain't gonna sink the ship.
perhaps there's a parallel ? ... teflon tape on temp senders screwed into heads-water jackets ...
... turns out the teflon does not prevent the sender's housing from grounding ...
... the threads cut through the tape; completing the circuit with no significant increase in resistance.
I agree with your comment that sufficient force will push through it. And it's pretty incredible how small the actual area of metal to metal contact there is in most connections.
... yea, here's QA & QC ... suppose a "Q" is a more democratic representation ... but done it all separately & all at once. Oh; never published.
