Bracket
Old Jul 22, 2019 | 06:35 PM
TPI BOY's Avatar
TPI BOY
Default Bracket
What brackets do u use when mounting
a CS 144 alternator
Old Jul 23, 2019 | 05:52 PM
Mooser's Avatar
Mooser
SB or BB?
On my BB it was the stock bracket just modified to be a little longer
M
Old Jul 23, 2019 | 06:02 PM
TPI BOY's Avatar
TPI BOY
Its a small block with tall valve covers
Old Jul 23, 2019 | 09:51 PM
carriljc's Avatar
carriljc
3951337 is the lower bracket part number that I am using. I used the regular upper arm if I remember correctly. Nothing special.
https://www.corvetteforum.com/forums...post1596588909
and here is one for sale for 35 bucks...
https://www.ebay.com/itm/GM-ORIGINAL...oAAOSwDJdborDf
BUT --- I've had a 10si, 12si, and the CS-144 installed using this same bracket. I have used different size belts. You should check to see if you can use whatever it is that you have on there now.
To Bracket
