BB P/S Pump Mounting Question
New ones are on the way, but I have a question wrt installing them.
Do the mounting bolts (or more correctly, the threaded holes in the pump housing) have any connection to the power steering fluid (passages)? I'm concerned about oil contamination and/or oil spillage when I remove the old bolt(s). Thx
That said, the can is sealed to the pump body by them, here's a pic of the can so you can see where the bolt holes go (ignore the changes made for my hydroboost fittings) when you remove the bolt there's nothing really holding the reservoir can tight to the pump so fluid can seep out there, how much / fast I don't know
HIH
M
