Carburetor vs. EFI
I work with Delphi fuel injected vehicles everyday, 6 days a week. All of these aftermarket EFI systems are based on Delphi EFI. So they make perfect sense to me. But like my steering geometry thread. If you don't understand it at all in the first place. You eather learn. Or throw in the towel.
At the end of the day. EFI does have so much to offer. Hard to fault when it works. When it doesn't, like anything else. If you understand HOW it works. Makes all the difference in trouble shooting and repairing.
Benefits/no warm up issues/Good at any elevation
Cost
Installing new 3/8" supply and return lines
Installing exterior electric fuel pump or in tank pump.
If existing fuel tank is reused you'll have to drop it to install the 3/8" return line
Installing a new EFI fuel tank from Holley or Tanks Inc.
Installing new HEI distributor
or
No warm up issues/Good at any elevation
Install this Atomic EFI
Less cost
Easier installation
Watch the tech video of both the Sniper and Atomic.
Also installation of fuel lines with out the body raised or removed is not a pleasant endeavor ( be careful what you wish for).
Or as others have commented have Lars do a number on your carb, gain performance and drivability, save yourself money and potential grief.
Just my thoughts.
Best of luck
I like that the Sniper system has the injectors under the throttle body rather than on top - I can only imagine atomization is much better as the injectors aren’t showering the throttle blades with fuel. In fact, I wouldn’t be surprised if a carburetor would get better atomization at idle than the Atomic system.
I do a run through of the menus in the Atomic EFI programmer in this video, but at the tail end of it (cue to 1m55) you can see the injectors bathing the back of the throttle bodies:
Since I took that video, I’ve changed intakes twice and gone to computer controlled timing, which does stabilize the numbers quite a bit and help with changing throttle scenarios (like sudden throttle closure), helps anti-stall and responding to fans / AC kicking on.
If I was doing this all again and had no constraints on the build, between these two I’d consider the Sniper before the Atomic. There’s just a lot more control in the system and the aforementioned injector placement. I’d much rather have port fuel injection, though, and I’d prefer something like Edelbrock’s Pro-Flo before any TBI unit. Not to mention, the center mount throttle bodies on the port injection setups are quite a bit shorter than Holleys, Q-Jets, Sniper and Atomic TBIs - which is a lovely thing on our cars as we all know.
