Carburetor vs. EFI
I intend to install one in the Corvette, taking everything I learned from the install in my Pontiac and applying it to the '71 convertible. Using that filter regulator saved a ton of time, so I will do that again so I don't have to route a new return line the length of the car. I'm not sure I have the clearance for a spacer, but an L88 hood would solve that problem.
My other I run a Edelbrock which also runs great. No issues. Weiand manifold.
My other is a Q jet and it runs great - no issues.
The only issue I have with the fuel injection is: what happens when something goes wrong on a trip. With a carb I can walk into AutoZone and get one for $300 and be running in 20 minutes...
Lar's is this forums Q-jet guru and always seems more than willing to help...thanks. However, if your Q-jet is stock, unbutchered and you are mechanically minded....try rebuilding it yourself. Below is a link to a Cliff Ruggles Q-jet book. Read the book a couple of times and give it a try. If you go this route, my one piece of advice is to lay a big piece of cardboard on your workbench and document the pieces as you disassemble. Lay them down on the cardboard, write the name of the part next to it with a sharpie and take a pic with your phone. This step will assist in the reassembly and make you more comfortable with the various components. Cliff Ruggles also sells Q-jet rebuild kits.
Last comment on driveablity - make sure the timing curve and ignition are correct. Many point at the carb when they should be thinking about the ignition.
Best of luck and let us know your decision.
https://www.barnesandnoble.com/p/how...xoCpMAQAvD_BwE
Thank you for that advice, when this carb was rebuilt, I had a new HEI distributor installed along with ignition timing adjustments. I think ill
take a look at the timing and stuff too along with the carb.
Sure the EFI has its perks but unless it was 100% factory new car reliable why bother? An electric FP will fill the bowls quick for cars that sit.
Thanks for posting you saved me thousands
Fueling
To start with, any carb you can throw at the car should work with the stock fuel system. An EFI system will require at a minimum an electric pump put somewhere in the supply line. Your problems start here.
I went full-tilt on the fuel system, with an Aeromotive Phantom setup and two brand new AN-6 lines, a good regulator and filter setup. This guaranteed I wouldn't see pump starvation issues in hard acceleration (throttle, brake, steer) and with a return style system mitigates the risk of vapor lock.
The easiest system to setup would be an electric fuel pump tapped inline with the existing supply line, dead-headed with the carb. Vapor lock is more probable with a PWM, and the factory line may not handle the higher demands of fuel injection (higher pressure, more vibration).
Oxygen sensor(s)
The oxygen sensor needs to be installed far enough from a junction point to get a good average of cylinders and there can not be any upstream exhaust leaks or nearby downstream exhaust leaks. These will skew the mixture and cause the ECM to run in circles attempting to figure out what's going on.
Vacuum Leaks
Not as big a deal as exhaust leaks, but a vacuum leak will cause the model the ECM uses to figure out your projected fueling needs to be less predictable.
Some Tuning Required
Yes, EFI can compensate for a lot, but it won't know everything about your car and you'll need to help it along the way. You'll need to give it information about your camshaft, information about your desired timing curve, etc so that it can build a close enough model to base its assumptions on.
USE COMPUTER CONTROLLED SPARK!!
This is a HUGE one for me. The EFI ECM is designed to control combustion. Yes, it's called "Electronic Fuel Injection", but every system worth its salt is also going to have timing control capabilities. USE THEM, or stick with a carburetor. I'm serious. The carburetor's metering capabilities are capable of "good enough" to get you down the road, but the EFI is capable of getting things perfect - and it can control transient throttle conditions and idle much better with timing than it can controlling via fuel mixtures and IAC alone. If your ECM wants to throttle down the motor a bit, it's much easier for it to do that via spark than by playing with IAC.
I ran my car with the MSD Atomic EFI and the HEI distributor for maybe a month before investing in a full computer controlled timing setup. Night and day. The A/C system kickup, which included exciting one of the electric fans was more predictable, the car was less prone to stalling, and leaning into the gas pedal was much smoother. Absolutely worth it.
I do enjoy my EFI system. I would probably skip past TBI and go straight to a multiport, sequential system if I could. I like port injection - better fuel economy, better part throttle, plus the center-mount throttle bodies have just a little less stack height vs a carb or TBI unit if you're trying to sneak a larger intake under a Corvette hood.
Hope that helps.
can't begin to compare the difference in overall driveability. Soooo, much nicer with EFI. starts, runs, at every RPM so much smoother, cleaner with EFI. No I don't drive around with a screen lit up all the time. What nonsense! I don't do that with my late model car or motorcycle!
But once I did. As I wanted to compare the temp readings through the ECU against the guage in my center guage cluster. While I was at it I also ran the AFR's on the screen just for giggles. Yes I learned my cars temp guage reads high. And was amazed at how the ECU kept the AFR's adjusted near perfect all the time.
with both carbs, when it sat for more than a day, it never, not once started on the first crank. Always took a second cranking to get it to fire. Never got the choke just right on either carb. Shut off to late, or to early. Never just right. EFI. Turn the key and go. Idles up for 30 seconds cold. Settles down and good for the day. Yes a bit of monkeying around in the beginning getting the map set up to my cam, compression, etc. But really just pushing buttons. Spent more time playing with fan start and shut off timing than anything. Only to learn my guage isn't accurate. If my EFI system does fail one day. By then they'll have something better I reckon. As per running into a Autoparts store and just grabbing a carburetor if one is on a road trip. Yah, cars haven't run carbs in HOW LONG! Not that many shops still stocking a selection of carburetors anymore. More likely to find an IAC or IAT.
so I thought I would give it a shot since it was my end goal anyway. I plan on multiple cross country trips in the future and crossing the great divide will require it if I want it to perform well at altitude. I got it installed and it fired right up. The only issues I've really had was from me messing with it trying to tune it before it was done learning. Once I stopped monkeying with it the gas mileage started going up. I used the Holley in tank pump/ regulator and sender. Its plumbed to the original 3/8 line and the 1/4 inch return isnt attached yet. I do plan on hooking it up as a back up, just waiting on braided hose ends. At close to 500 hp the 3/8 is holding its own. No starvation problems. If I do notice them I'll just run braided line the whole length.
Now im messing with my gas gauge. Im giving this a shot
Classic Instruments Fuel Link Interface Modules SN34
https://www.summitracing.com/parts/CIN-SN34Last edited by Rescue Rogers; Oct 10, 2020 at 07:18 AM.
My 69 had a 434 SBC with a spread bore Holley with the choke removed. 2 pumps to start, a little feathering, then off we go. Started to have idle surging problems that were getting worse and after going through the carb twice I decided that come off season it would get a Holley Sniper along with a new tank from Tanks inc, with the built in fuel pump, new lines, etc. Now the fun begins. The first summer there was dying out problems that were finally diagnosed as excessive RFI [ ever try contacting Holley service] and resolving the problem by putting tin foil around the wiring and using the OEM chrome shielding that problem is finally corrected. Next the engine races up to 1800 rpm when restarting after being shut off 5 minutes earlier. Now it is surging again, but this time it is a failing injector, you can see that but cannot fix it. Or can you? I have a spare Quick fuel carb sitting in a box that is just begging to be put on, my off season project and it won't cost me 2 grand. Anybody want to buy a slightly used Holley Sniper? T
