Power Window Switch Alternative
Old Aug 14, 2019 | 07:43 PM
DC3's Avatar
DC3
Originally Posted by Richard454
The relay/fuse holders- the ones I've used are by "Littlefuse"
They use standard Delphi Metri-Pack Series 280 terminals.
https://www.waytekwire.com/item/4598...-Distribution/
Here's the relays- they (Waytek) carry the SPST and SPDT type
https://www.waytekwire.com/item/7573...-Micro-Relay-/
Perfect. Thank you.
DC
Old Aug 28, 2025 | 08:39 PM
Adel_Volks's Avatar
Adel_Volks
Navigator
Default Did they last?
Originally Posted by DC3
This is what I came up with:
Hello, DC!
I know this was 6 years ago, but wondering how your switches hold up all those years?
i’m willing to try your mod! Getting tired from faulty switches. Your feedback would be appreciated.
Thank you,
Adel
Old Aug 30, 2025 | 10:50 PM
TorchZ51's Avatar
TorchZ51
OEM wiring- has full power running through the switches- the contacts are subject to arcing and the voltage drop will not let the motors work at their best. So replacing the switches that are of a better quality really don't solve the problem.
Using four Bosch relays to control the up and down - the motors will run faster and the switches will last forever.
In pic- Right side -the relays have been added- left side is OEM wiring
I'm actually running Jaguar (Lucas- the prince of darkness) switches in mine with relays!!!
Well I learned something new. Never crossed my mind to install relays for faster power window operation. I’ve ordered the micro relays and bases for my next project.
Old Aug 31, 2025 | 09:24 PM
DC3's Avatar
DC3
Originally Posted by Adel_Volks
Hello, DC!
Thank you,
Adel
Yes, they have held up very well. No issues at all.
But, I do have to tell you that I've since upgraded to using relays like Richard described. I didn't do this because I was having problems though. I did it because I had some of the interior apart for another reason, I had some extra relays, and just thought I would do it while everything was exposed and easy to access.
Good luck,
DC
