Catch cans
Old Aug 20, 2019 | 05:25 PM
REELAV8R's Avatar
REELAV8R
On my C3 with its 427 I still use a PCV on my valve covers. I like to see the nasty blow by get burned in a car like mine as it runs rich and has a big carburetor. Having a vacuum in your engine will help the rings seat and stay sealed up the best they can.
If you have PCV valves on both valve covers, do you have a source to introduce fresh air into the crankcase?
Old Aug 20, 2019 | 06:07 PM
HeadsU.P.'s Avatar
HeadsU.P.
There was a guy on here last year with a vacuum hose to each valve cover, then to the intake. I asked him how he was introducing fresh-air into the crankcase to replace what was removed.
No response.
I said, you can't run two negative pressure (vacuum withdrawl) lines to a crankcase without a positive air introduction (replacement).
Still no response.
In laymans terms, I wrote, you can't have two successful outlets with no inlet.
STILL no response. I guess he just didn't get it.
Old Aug 20, 2019 | 06:26 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Maybe he thought the blow-by was good enough.
Old Aug 20, 2019 | 06:47 PM
jackson's Avatar
jackson
http://blog.wiseco.com/common-causes...il-consumption
http://mewagner.com/
Old Aug 21, 2019 | 03:21 PM
REELAV8R's Avatar
REELAV8R
Good read Jackson. I popped for the M/E wagner PCV a year or two ago, a very nice quality item IMO.
