Front crank seal.
Old Aug 21, 2019 | 01:00 PM
kodpkd's Avatar
kodpkd
Default Front crank seal.
I want to replace my leaking front seal. I don't have the ability to remove the engine. I need advice on what to remove to get at the seal. Do I need to remove the hood to get at the front of the engine? I know to remove the fan, bottom pulley, balancer, and probably the fan shroud,,, but not sure the best way to access it.
Old Aug 21, 2019 | 01:22 PM
Kacyc3's Avatar
Kacyc3
Are you sure it s the seal at in the timing cover for the crank and not the balancer sleeve or oil pan gasket?
Old Aug 21, 2019 | 01:31 PM
SH-60B's Avatar
SH-60B
Yes, remove the things you mentioned, but leave the hood on. You'll need to lower the front of the oil pan, then remove the cover to r+r the seal.
Old Aug 21, 2019 | 01:40 PM
kodpkd's Avatar
kodpkd
Forgot to mention. This is on a 1968 327/350. I have already replaced the oil pan gasket with a one piece, and the rear main seal. I don't think it has a sleeve.
Old Aug 21, 2019 | 04:05 PM
Kacyc3's Avatar
Kacyc3
That could be the problem unless this is a new balancer and a seal hasnt worn a groove in the shank that slides on the crank.
Old Aug 21, 2019 | 06:06 PM
jackson's Avatar
jackson
The timing cover seal can & will wear a groove in damper's snout.
You can get a "redi-sleeve" that repairs the snout ...also replace the seal.
Pioneer , timken etc have the sleeves
https://www.summitracing.com/search/...rder=Ascending
Old Aug 21, 2019 | 07:43 PM
kodpkd's Avatar
kodpkd
Thanks for the info... once I get the balancer off, I can figure out why it's leaking. For now,,, help on how to get at the front of the engine would be good.
Old Aug 21, 2019 | 08:15 PM
jackson's Avatar
jackson
Remove:
Fan shroud .***** then cut a piece of cardboard to cover engine side of radiator ... fins cut your knuckles and get bent
Fan & Clutch
All belts
Lower pulleys
Water pump
*********** borrow a tool from parts store to remove harmonic balancer / damper ... inspect damper snout for groove
Old Aug 21, 2019 | 08:23 PM
kodpkd's Avatar
kodpkd
Originally Posted by jackson
Remove:
Fan & Clutch
All belts
Lower pulleys
Water pump
Not sure why the water pump would have to come off. Mine is a 68,,, no fan clutch.
Old Aug 21, 2019 | 08:37 PM
jackson's Avatar
jackson
You might take the timing cover off ... water pump first.
Old Aug 21, 2019 | 09:56 PM
derekderek's Avatar
derekderek
Another option to repair sleeve is leave the seal out about an eighth inch.
Old Aug 22, 2019 | 12:23 AM
7T1vette's Avatar
7T1vette
As long as you can keep the seal 'square' to the bore AND the outer casing can still seal properly, that will work, also.
To Front crank seal.
