throttle cable connection
Old Aug 22, 2019 | 10:40 AM
jim-81's Avatar
jim-81
Default throttle cable connection
OK sort of a dumb question but what is this rubber part that fits in the throttle lever on the carb that allows you to connect the throttle cable? It's a nut inside with a rubber sleeve that fits in the large hole. Mine is a little ragged and I'd like to get a new one but don't know what it's called!
Old Aug 22, 2019 | 10:48 AM
Kacyc3's Avatar
Kacyc3
should be a stud far as I know.
throttle stud
Old Aug 22, 2019 | 11:32 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Since it's a aftermarket carburetor, make sure that you can get full throttle travel when the pedal is depressed fully.
Old Aug 22, 2019 | 12:59 PM
MelWff's Avatar
MelWff
the part would be called a throttle lever bushing or grommet
Old Aug 22, 2019 | 01:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I agree. Contact Edelbrock Customer Support and ask.
Old Aug 23, 2019 | 04:47 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I would put a stud in that lower hole for better throttle response with less pedal. I 've never seeen a grommet like that before
Old Aug 24, 2019 | 02:52 PM
lars's Avatar
lars
Actually, all the C2 Vettes with Holley carbs used the rubber grommet with the plastic sleeve. The C2's have a throttle rod with a 90-degree bend in the end that then goes through the grommet - that's the reason for it. On a C3 with a cable and a hole in the swaged cable end, you do not want to use the C2 style rubber grommet - that's a real Bubba-setup you have going there. Install a screw-in stud in the throttle lever and hook up the throttle cable directly to the stud. The stud should be in the lower hole - not the top hole, to assure full throttle travel.
Lars
Old Aug 25, 2019 | 11:09 AM
lars's Avatar
lars
See photos of the C2-type rubber grommet connection here, and the problem with using the top mounting hole in the lever. For C3, do not use the rubber grommet - install a correct stud in the lower hole in the lever and directly attach the cable the way the stock setup is done:
https://www.corvetteforum.com/forums...oto-story.html
Lars
Old Aug 26, 2019 | 08:31 AM
jim-81's Avatar
jim-81
Thanks - I will look into this and get it fixed. I have checked out at the Lokar throttle cables and they look good. For some reason my throttle cable has the flat hole at the end, not sure where it came from, it has been on the car the entire time I have had it.
thanks
Old Aug 26, 2019 | 10:24 AM
lars's Avatar
lars
As noted earlier, the cable is set up for a stud - the flat hole at the end is correct - you don't need to change cable. Just install a correct stud in the throttle lever and attach the cable like the stock setup.
Lars
Old Aug 26, 2019 | 10:34 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Mr. Gasket makes the stud.....Edelbrock has them too for twice the money.
Put the stud in the circled hole.
Jebby
Old Sep 4, 2019 | 01:02 PM
jim-81's Avatar
jim-81
OK well I went ahead and ordered a Lokar throttle cable and the stud for the carb and it is much nicer. The Lokar cable and brackets are very well made and actually came with helpful instructions. From the old cable, I cut off the end by the pedal and reused the little plastic sleeve. Works great now.
from underneath
I used this cable: https://www.summitracing.com/parts/lok-tc-1000ht
and this bracket: https://www.summitracing.com/parts/lok-srk-4000
Jim
Old Sep 4, 2019 | 01:03 PM
jim-81's Avatar
jim-81
I can't believe I was using the wrong hole in the carb for EIGHT YEARS!! lol
Old Sep 4, 2019 | 01:27 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Little things......
It is quite possible you were not getting WOT either!
Jebby
Old Sep 4, 2019 | 07:08 PM
Rescue Rogers
Let us know if you notice any performance difference
To throttle cable connection
