Air Compressor
Old Nov 11, 2002 | 06:27 PM
79corvette's Avatar
79corvette
Default Air Compressor
I want to replace my valve steim seals. In my repair manuels it says to hook up compressed air where the sparkplug is to hold the valve up while I take the valve spring out. So here's my question, What size air compressor should I get, such as tank size and HP? I'm 16, so I am on a budget(if there is such a thing with a Corvette). Thanks for the help.
Also, anyone else having problems viewing posts?
Old Nov 11, 2002 | 09:22 PM
Larry B.'s Avatar
Larry B.
Default Re: Air Compressor (79corvette)
You can do the same job by removing the spark plugs and feeding a few inches of clean slick nylon rope into the cylindres (one at a time of course). Pull the engine up onto the compression stroke and the rope will hold the valves up. actually it is safer than compressed air and a whole lot cheaper the a compressor. If you need any more info on that method feel free to e.mail me. The forum seems OK at the moment.
Old Nov 11, 2002 | 09:31 PM
69shark's Avatar
69shark
From: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Air Compressor (silvervetteman)
I have heard of the same method with clothes line rope :cheers:
Old Nov 12, 2002 | 05:42 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Default Re: Air Compressor (69shark)
i've done it this way a couple times myself. pretty much any type of rope will work as long as it is long and flexable enough. last time i used two boot laces tied together. works fine.
Old Nov 12, 2002 | 10:36 PM
79corvette's Avatar
79corvette
Thanks for all of the great advice. Will work slowly on it this week.
To Air Compressor
