Side pipe back fire
Old Aug 30, 2019 | 06:53 PM
Dr1rrrr's Avatar
Dr1rrrr
Default Side pipe back fire
Just installed a set of side pipes on my 78 l82 and first off I love the way they look and sound except for one sound. I'm getting a slight back fire on deceleration it's a not very loud but a crisp pop. Also at about 2500 rpm the engine surges and pops I've tuned the idle mixture needles and no change. The baffles I'm running is the hooker reverse flow, I know they kill a lot of power but I don't want my car to be insanely loud. I was thinking those might be causing me to run rich but I wanted to see what you guys thought.
Old Aug 31, 2019 | 12:29 AM
REELAV8R's Avatar
REELAV8R
Sounds too lean. Main jet change may be in order.
Old Aug 31, 2019 | 12:40 AM
Dr1rrrr's Avatar
Dr1rrrr
How much of a jet change should I do?
Old Aug 31, 2019 | 03:54 AM
Gunfighter13's Avatar
Gunfighter13
What carburetor do you have? Stock engine or mods?
Old Aug 31, 2019 | 05:49 AM
cooper9811's Avatar
cooper9811
Try 2 jet sizes on the primaries, see how it behaves.
Old Aug 31, 2019 | 07:14 AM
CrossedUp's Avatar
CrossedUp
An exhaust leak can cause a backfire.
Old Aug 31, 2019 | 08:58 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
If your car was previously stock, and running on the OE single exhaust, and running well, then adding a full dual system, with headers feeding into those rather large sidetubes, reverse flow mufflers notwithstanding, you're most likely running lean....
Old Aug 31, 2019 | 09:31 AM
stingr69's Avatar
stingr69
Agreed - Recheck the header bolts. They loosten themselves especially when new and need to be retightened a few times before they stay tight.
BTW - The term "Backfire" refers to popping up out the carb. "afterfire" is popping out the exhaust.
If the gaskets are not leaking at the head, you may be experiencing a lean misfire causing the afterfire. Thats when the throttle is closed quickly and you get lots of air bypassing the edges of the throttle blades without enough gasoline to ignite the mixture properly. The mixture will misfire, and the unburned fuel ignites in the hot exhaust stream causing the tiny popping explosions you hear.
If it did not afterfire before the headers were installed (without any other carb changes), my money would be on an exhaust leak at the header to cylinder head joint.
Old Aug 31, 2019 | 10:03 AM
Gunfighter13
Round port heads with Rectangular port header......nothing can go wrong there......
That would give most men an excuse to buy a new cam and set of aluminum heads.........
Old Aug 31, 2019 | 10:41 AM
7t9l82's Avatar
7t9l82
Check your jetting. If you had an exhaust leak you'd hear it or even feel it moving your hand beside the headers.
Old Aug 31, 2019 | 12:09 PM
Dr1rrrr's Avatar
Dr1rrrr
I've checked the header bolts they aren't loose yet and I did previously have the oe exhaust system and it was running good and my engine is all stock. I pulled the plugs today and they are all white so I'm thinking you guys are right it's Lean so I guess to main jet sizes?
Old Aug 31, 2019 | 01:28 PM
Kirk H's Avatar
Kirk H
Before you start changing jet sizes, which you may end up having to do, pull off your air pump belt (if your headers have the A.I.R. tubes hooked up to them) and see if not pumping in air into your headers makes any difference. Your diverter valve or the vacuum line it uses may be causing an issue. It's an easy and quick check.
Old Aug 31, 2019 | 02:03 PM
leadfoot4's Avatar
leadfoot4
I know that this sounds a little off the wall, but if carb re-jetting isn't your favorite task, I'd suggest possibly switching to a Holley, spread-bore replacement carb. I'm not suggesting that the Rochester Q-Jet that you probably have, isn't a good carb, it's just that Rochester Products hasn't made any of them in over 30 years, and tuning parts are pretty scarce. The Holley is still being made, and parts are plentiful.
Old Aug 31, 2019 | 03:05 PM
Dr1rrrr's Avatar
Dr1rrrr
I have thought about a Holley I think I'm going to try the qjet first but what Holley carb would be comparable and I forgot to mention the air pump is removed from my car.
Old Sep 1, 2019 | 08:45 AM
leadfoot4's Avatar
leadfoot4
Holley makes a "spread bore replacement" carb, that has the same throttle bore spacing as the Q-Jet, so you can retain the OE intake manifold. I don't know the model number offhand, but the "mail order speed shops" have it listed in their catalogs.
Old Sep 1, 2019 | 03:55 PM
lars's Avatar
lars
Afterfire in the exhaust on decel is a lean condition. Increase jet size 2 sizes (unless you already have 77 jets in it), raise the APT setting as outlined in my carb setup paper, and get your float level set to .300". Make sure idle mixture screws are not set too lean. Going from a restrictive stock exhaust to a free-flowing true dual setup will lean you out, and it will make it pop in the exhaust. Richen it up.
Lars
Old Sep 1, 2019 | 04:03 PM
Dr1rrrr's Avatar
Dr1rrrr
Thanks guys for all the help I'm going to to try to get all the work done next week so I'll post the results.
To Side pipe back fire
Old Sep 1, 2019 | 04:50 PM
Dr1rrrr's Avatar
Dr1rrrr
So I just looked at your paper and it says for my number carb it says it comes stock with a 77 so if it already has 77 jets in it when I take it apart would I have to use metering rods to richen it? It's that correct?
Old Sep 1, 2019 | 05:39 PM
7t9l82's Avatar
7t9l82
His headers don't have fittings for that garbage, thankfully.
Old Sep 2, 2019 | 10:14 AM
lars's Avatar
lars
If you're already at 77, do the rest of the "Quickie Performance Setup" processes as outlined in my Q-Jet paper (e-mail me if you need a copy). This includes raising the APT to where it needs to be and getting the float level up to spec for a performance application. This, along with getting the idle mixture screws correctly set, will fix the problem and get you into the correct mixture range to avoid the afterfire in the exhaust.
Lars
V8FastCars@msn.com
