CEL Question
Old Sep 16, 2019 | 06:53 PM
JacksC3's Avatar
JacksC3
Default CEL Question
My 1982 Corvette CEL comes on for about a minute when its warmed up and is going about 60mph down the road. Any ideas why? Thank you.
Old Sep 16, 2019 | 11:11 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Do you know how to read the trouble codes? That will provide you with the definitive issue.
If we’re guessing, I’d guess oxygen sensor.
Old Sep 17, 2019 | 10:09 AM
JacksC3's Avatar
JacksC3
Yes, I will try to read the code, but the CEL usually pops up when I'm going about 60mph on a highway and shuts off in about a minute afterwards. Next time hopefully I will have a convenient place to pull over and check the code before it shuts off. Does the CEL have to be on to see the trouble code?
Old Sep 17, 2019 | 10:31 AM
derekderek's Avatar
derekderek
I'm pretty sure it holds the CEL codes for a while after the light goes off. So you can still see what it was.
Old Sep 17, 2019 | 11:23 AM
CA-Legal-Vette
Old Sep 17, 2019 | 12:20 PM
gbvette62's Avatar
gbvette62
On 82 Corvettes, codes are saved for 50 restarts, or until the battery is disconnected, which ever occurs first. If you still have the original ETR radio, you can do a quick check for any codes by removing the ashtray, and jumping posts A & B in the terminal under the ashtray. Any stored codes will be displayed on the digital face of the ETR radio.
Old Sep 17, 2019 | 03:44 PM
JacksC3's Avatar
JacksC3
Yes, it still has the original radio, I will check that. Thank you so much.
Old Sep 17, 2019 | 03:58 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Sorry, not true about radio, but you can still retrieve the fault codes via the ALDL connector under the ash tray as depicted below looking at it with a paper clip and watching the CEL light flash. Also, the codes will not dump until battery power is removed from the ECM which can easily be done by pulling the 20amp fuse in the battery compartment for about 30 seconds(ish) vs. disconnecting the battery. Do you have a 82 GM service manual? All this information is in there on how to do it and fault code meaning. Since I have the EBL Flash II on mine, I just hook up the laptop with "What's Up" and it tells me what's going on instantly, but on a stock CF, no point really. "A" is Ground and "B" is Diag Term.
Old Sep 17, 2019 | 06:23 PM
L-46man's Avatar
L-46man
Jack mine did the same thing...would Light the CEL, then go off a minute later with no codes.
Yes, first check the OXS and wiring.
Second, run the codes by probing the ALDL.
Very sensitive to vacuum leaks esp. the huge manifold.
Run engine vacuum test.
Edit; Buccy is right (he always is, er ahem, annoyingly! lol) the code reads off of the CEL light.....blinks successively three times....for those of us who are slow to count!
If you post up the codes....you can look them up on the net or probably here....We'll help you interpret.
Let us know.....
Unkahal
Old Sep 17, 2019 | 06:26 PM
L-46man's Avatar
L-46man
Bucky! Your'e back from Hibernation! You KNOW where I'll be on Saturday at 5:00pm.....come out to play. Trying to roust up the C-3 crowd.
Unkahal
Old Sep 17, 2019 | 06:57 PM
Buccaneer's Avatar
Buccaneer
You-a-funny-guy! You know I'm always right, right? LOL Wha, I only took five weeks vacation. I may be at Pav Saturday, not completely sure yet. I still have the headers uncorked, so I have to put the exhaust back on just to drive out there, but it would be impressive to roll in uncorked.
Old Sep 18, 2019 | 10:08 PM
JacksC3's Avatar
JacksC3
You all have been great, thank you for the info. I will check the vette this weekend, thanks again
Old Sep 22, 2019 | 01:43 PM
JacksC3's Avatar
JacksC3
Well I tried checking the codes. I viewed several videos on how to check the codes. All I get is the "1-1-2" continuously. Not sure what's going on. I feel confident that I'm doing it right. Supposed to have "1-1-2 three times, then the code, but all I get is "1-1-2" continuously.
Old Sep 22, 2019 | 03:23 PM
Buccaneer's Avatar
Buccaneer
That doesn't make sense. Are you sure you are not getting an 11 or 22 code? 22 would be your TPS which would make more sense that you would get it while moving vs. an 11 code which is IAC. Check your TPS with a meter. Key ON, engine off. See if it reads .525V. If not post what it reads. Also, while at it slowly move the TPS sensor while watching the meter. If it goes "open" or some crazy wild reading while moving it, the TPS is bad. You do have a GM 82 corvette service manual, right? If not, get one, you will need it.
Old Sep 22, 2019 | 03:47 PM
derekderek's Avatar
derekderek
1-1-2. 2 longs 2 quick? 2 long is 20 2 quickies are 2 more. 22.
Old Sep 22, 2019 | 04:03 PM
JacksC3's Avatar
JacksC3
I get 2 longs and 1 quick, then a long pause, then the same over and over.
Old Sep 22, 2019 | 04:09 PM
JacksC3's Avatar
JacksC3
Might be a stupid question, but where would the TPS be located?
To CEL Question
Old Sep 23, 2019 | 06:47 PM
Buccaneer's Avatar
Buccaneer
Not stupid, but it is located on the rear or drivers side TB and has three wires coming out of it. Two screws lock it down. I would highly suggest that you get a GM service manual before trying to trouble shoot your car in the future. It is definitely worth having on a car that is 37 years old and getting older. You can find them on eBay as well, but most are now kind of expensive. Code 21 is also a TPS fault.
Old Sep 23, 2019 | 10:39 PM
derekderek's Avatar
derekderek
https://www.troublecodes.net/gm/
Old Sep 24, 2019 | 09:52 AM
7T1vette's Avatar
7T1vette
If no trouble codes are retained, then your problem is an 'out of tolerance' sensor or an intermittent sensor. The Service Manual for your model year should have diagnostic test to help you determine which sensor is the problem. If you have installed an aftermarket CAT, it could be that the replacement does not have the same capacity as the original unit.
