79 died while driving
Old Sep 21, 2019 | 12:16 PM
Jason 1979's Avatar
Jason 1979
Default 79 died while driving
I was driving home from work yesterday and the car lost engine power every couple of seconds, started misfiring and finally died. Pulled off the road and tried to restart, it would catch occasionally but was running really rough and backfiring out of the exhaust. I had it towed home and tried starting it this morning, caught for a second or two a couple times, but still running really poorly.
pulled air cleaner to see if it is getting gas, it is. That pretty much only leaves ignition, is that correct?
Old Sep 21, 2019 | 12:46 PM
elmo771's Avatar
elmo771
Might have jumped time, maybe timing chain?
Old Sep 21, 2019 | 12:57 PM
Jason 1979's Avatar
Jason 1979
Ok, let me restate the question. Giving the facts above, does it make sense to check the ignition first?
I have all new MSD ignition stuff setting on a shelf for install this winter. I could move that up to tomorrow.
Old Sep 21, 2019 | 02:28 PM
TimAT's Avatar
TimAT
Pop the distributor cap -- put a socket on the crank bolt and turn the engine- see if the distributor rotor moves with the crankshaft. If you pull the spark plugs you can roll it backward and not have to worry about the crank bolt. I'd bet on the timing chain/upper gear shedding it's nylon teeth.
But absolutely YES- check the ignition first. Always start with the easy/cheap stuff- always.
Old Sep 21, 2019 | 04:02 PM
jackson's Avatar
jackson
agree on each point
Old Sep 21, 2019 | 04:31 PM
Jason 1979's Avatar
Jason 1979
Would it ever start with the timing chain in that condition?
if the seller is to be believed this engine only has about 2,000 miles on it since rebuild.
Old Sep 21, 2019 | 05:18 PM
Duane4238's Avatar
Duane4238
But you don't know if the timing gear (nylon) was replaced in the rebuild. If the gear lost a tooth or two while you were driving, it would die on the quick. Also, don't go changing things with the MSD until you figure out what went wrong. Good luck.
Duane
Old Sep 21, 2019 | 05:27 PM
HeadsU.P.'s Avatar
HeadsU.P.
IGN Modules usually, but not always, just die without much warning once they get hot. Waiting 30 min or so for cool down and the modge will be fine, start right up.
The modge has circuit board type wiring inside. The heat breaks the contacts, shuts everything off.
A coil may be erratic. They seldom fail, but again, should work after cool down.
Your next step is verifying a good, strong spark at a plug.
Old Sep 21, 2019 | 08:46 PM
Jason 1979's Avatar
Jason 1979
So, here is my plan for tomorrow.
1) pull a plug and check for spark.
2) if spark, pull all of the plugs and check them out. While the plugs are out, turn the crank and see if rotor moves. If rotor moves see if it is pointing to 1 at TDC. That should eliminate timing chain.
3) if no spark, check to see if distributor is getting 12v at various key positions. If so, replace all of that with the parts I have on hand. If not, find out why.
That sound about right?
Old Sep 21, 2019 | 09:20 PM
HeadsU.P.'s Avatar
HeadsU.P.
Yes. You want all that done before one, NFL kickoff time.
Keep it simple for now. Could be those IGN wire harness clips on the side of the distributor cap. Or module harness connection.
While the cap is off, take a dry paper towel and wipe the inside clean of "carbon tracking".
Old Sep 21, 2019 | 10:22 PM
jackson's Avatar
jackson
Yes ...AND ... $10 worth of cleanup & spruce-spray paint has rebuilt fleets of motors.
Old Sep 22, 2019 | 01:40 AM
Gunfighter13's Avatar
Gunfighter13
Sounds like a bad Ignition control module.
Old Sep 22, 2019 | 09:47 AM
Tampa Jerry's Avatar
Tampa Jerry
If you suspect that an ignition component is heating up and failing, get a can of dust off or other product that sprays compressed air. Its spray will cool a component down very quickly and point you in the right direction. Jerry
Old Sep 22, 2019 | 09:56 AM
derekderek's Avatar
derekderek
very few nylon timing gears are still out there. plastic ages whether driven or not. almost 0 chance of that. got timing light? also works as a spark checker.
Old Sep 22, 2019 | 10:01 AM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
Old Sep 22, 2019 | 10:20 AM
elmo771's Avatar
elmo771
We used to call these Sherwin-Williams rebuilds when I operated Equipment
Old Sep 22, 2019 | 11:29 AM
OldCarBum's Avatar
OldCarBum
Coils are cheap and you can swap one out in about ten minutes.
I would start there then start tearing things apart.
To 79 died while driving
Old Sep 22, 2019 | 12:16 PM
Jason 1979's Avatar
Jason 1979
Getting a spark on number 1 and 3, was doing it by myself so kinda hard to get a good read on it. It seemed weak and not regular. The tool I had to check it said set at 35 for Chevy hei, it would not arc at 35, had to close the gap down to 20 to get an arc.
I need a better tool to get the plugs out, ordered.
Old Sep 22, 2019 | 02:14 PM
HeadsU.P.'s Avatar
HeadsU.P.
Because of my headers, three out of eight plugs I can't use a ratchet on it. I put either an open-end or a box-end wrench on the 3/8 drive sparkplug socket.
And sometimes you are better off reaching plugs from underneath using ramps, if that helps.
Old Sep 22, 2019 | 06:28 PM
Devs77's Avatar
Devs77
Go through socket set from HF
I have headers and it was almost impossible to get to some of the plugs. This set makes life a lot easier!
