cam install
Old Sep 24, 2019 | 05:40 PM
capnron3's Avatar
capnron3
Default cam install
have 82 vette do I need to pull motor to install heads and cam?
Old Sep 24, 2019 | 05:44 PM
Fast81's Avatar
Fast81
while it would be easier, you dont have to. Heads can easily be done with the motor in the car, but you'll need to pull the radiator to do the cam. At least that's what we had to do with our 82 project that we are mid-rebuild on.
what heads/cam you using ?
Old Sep 24, 2019 | 06:11 PM
HeadsU.P.'s Avatar
HeadsU.P.
Its not that bad of job "in the car". Why make more work for yourself pulling everything when its not needed.
Get a helper to remove the hood, store it upright.
Remove fan belts, all hoses.
Remove clutch fan
Loosen shroud and lay it on W.P.
Remove Rad (carefully)
NOW remove shroud.
Then W.P. Vibration Damper, timing cover.
The A/C condenser can be left. Just loosen four bracket bolts and force the unit forward. That will just clear the end of the cam.
Old Sep 24, 2019 | 06:14 PM
capnron3's Avatar
capnron3
thanks ,not sure yet still have to do some research up for suggestions ,are this dish or dome pistons on these cars?
Old Sep 24, 2019 | 06:23 PM
HeadsU.P.'s Avatar
HeadsU.P.
Would also highly recommend getting the front end up on ramps. You will need access to rad hoses, shroud, front oil pan bolts, and will save you from a backache.
You will be surprised how fast all this goes. Time consuming is getting the exhaust away from the heads.
Old Sep 24, 2019 | 06:40 PM
L-46man's Avatar
L-46man
9.0;1 ratio....Dished.
Why Cam.? is it flat.? It's basically a L-82 Cam...I'd recommend a new manifold...+ 36hp JUST for that. (Renegade/ Jegs)
unkahal
Old Sep 25, 2019 | 07:04 PM
capnron3's Avatar
capnron3
yes was thinkin of trying that first thanks
Old Sep 25, 2019 | 07:28 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Just to say a little something here about an 82, this also goes for the 84. If your going to use the stock ECM and replace the cam and heads for whatever the reason. MAKE SURE YOU DO NOT STRAY TOO FAR FROM THE STOCK DURATION ON YOUR CAM CHOICE. If you do, you WILL have a lot of issues and cost you more money in the long run. I just wanted to let you know that before you buy a cam that is way to much for the ECM to handle since you will not be able to tune the 82 stock ECM. Also, you can replace both without pulling the motor, but much easier if you do. The shroud can be a PITA to remove. I hope this helps.
Old Sep 26, 2019 | 04:40 PM
L-46man's Avatar
L-46man
I am VERY WELL AWARE OF THAT....the L-83 cam and the L-82 cam are VERY similar.
carry on!
unkahal
Old Sep 26, 2019 | 07:03 PM
wilcar's Avatar
wilcar
L82 cam has 224 224 duration @ .050 and L83 cam has 202 206 duration, so not that similar in my opinion.
Old Sep 27, 2019 | 07:24 AM
augiedoggy's Avatar
augiedoggy
carry on!
unkahal
I think he was posting for the OP's benefit.
Old Sep 27, 2019 | 07:32 AM
Fast81's Avatar
Fast81
Pretty sure the 82 ECM will not play well with a 224 duration L82 cam, most have found about 212 on the intake side is the limit where you have to swap ECMs and start tuning yourself
Old Sep 27, 2019 | 09:44 AM
wilcar's Avatar
wilcar
I was in the same situation with my 84 C4 with "ceasefire system". Wanted more cam but did not want to have to mess with the computer and tbi tuning. Solved my issue and swapped my tbi xfire for a ZZ4 intake and 600 edelbrock carb. Just easier for me not having to mess with an ecm and tbi system. There was a reason the twin tbi system was short lived. I have a how to cheat sheet on how I did the carb conversion if interested.
Old Sep 27, 2019 | 12:40 PM
Buccaneer's Avatar
Buccaneer
This is usually the case with CF owners for whatever the reason. If it were me, the better route to take if you are going to replace the CF system is to go with a newer EFI system, but that's just me. Of course though, I like the CF and the look. I can get the performance out of the TBI system for what I'm trying to do with no problem. However, the reason the CF was so short lived wasn't because it was necessarily a POS system, it was a stop gap for the newer injection system that was forth coming in the 85 and up models on corvette. As a matter of fact, the TBI system was used all the way through 95 models I believe, at least on trucks and was a dual injector TBI unit on the 4.3L.
ALSO...
augiedoggy - Correct!
Fast81 - Correct!
Old Sep 27, 2019 | 12:59 PM
L-46man's Avatar
L-46man
The TBI system WAS NOT 'short lived'....it was just two years in Corvette...... It was available in CHEVY TRUCKS for the rest of the decade...I had an 88 K-5 Blazer with single TBI. NEVER HAD A PROBLEM even at 68 degrees below zero.
they made 100's of thousands of them....
Old Sep 27, 2019 | 02:13 PM
jackson's Avatar
jackson
dish aka "sump head" ref p 41 below ... but when you pull head, you'll KNOW for sure
https://www.gmheritagecenter.com/doc...t-Corvette.pdf
see full MY 1982 L83 spec above ... straight from the General's mouth ... GM
pages 39 - 44
losta combustion chamber, gasket etc dimensioning at above GM reference source ... download & save it
Old Sep 27, 2019 | 03:30 PM
jb78L-82's Avatar
jb78L-82
Ok Let's try this one more time:
The L-82 cam is 222 duration (NOT 224) with .450/.460 lift
The L-83 camshaft is 202/206 duration with .410/.423
These 2 cams are NOT even remotely similar...............very different
The L-83 cam has the lift and duration of a typical passenger car V8 engine, designed for LOW RPM torque. The L-82 cam is a mid to high RPM flat tappet cam from the same era........
To cam install
Old Sep 27, 2019 | 04:11 PM
wilcar's Avatar
wilcar
If you read my post again you will see that I said the TWIN tbi system was short lived. Also my source ( SWC Duke on this forum) showed the L82 cam had 224-224 duration but could be wrong. Even at 222-222 @ .050 duration the L82 is not similar to the L83 cam. L83 cam has same basic specs as the L69 305 HO engine used in early 80s Firebird, Camaro, and Monte Carlo cars.
Old Sep 27, 2019 | 04:59 PM
7t9l82's Avatar
7t9l82
The camshaft is just the beginning of the problem the cylinder heads are garbage and so is that intake manifold just look at the size of the ports on those things.
Old Sep 27, 2019 | 05:03 PM
jb78L-82's Avatar
jb78L-82
This comes up periodically about the L-82 duration:
These are the numbers I have seen since buying my 79 L-82 nearly 37 years ago.
Chevrolet Performance 3896962
•222 / 222 Duration @ .050''
•.450'' / .460'' lift
•114 Lobe Separation Angle
