Rear composite spring heat shield
Old Sep 30, 2019 | 11:17 PM
Jason Pelt's Avatar
Jason Pelt
1st Gear
Default Rear composite spring heat shield
Rear composite spring heat shield - So if I plan to run side pipes on my C3 build I should not have to install the heat shield on the rear composite spring, does this sound right to the group?
Old Oct 1, 2019 | 06:59 AM
Mooser's Avatar
Mooser
It's purely for protecting the spring from exhaust so you shouldn't need it with side pipes
M
Old Oct 1, 2019 | 08:07 AM
jb78L-82's Avatar
jb78L-82
M
Save it for future use if you change your mind about sidepipes or offer it for sale. Many forum members are often looking for that missing shield especially with the composite rear monospring if they replace the OEM steel one.
Old Oct 1, 2019 | 03:28 PM
7T1vette's Avatar
7T1vette
You are correct. But, it's no big deal to install the heat shield, anyway. If you decide later to go with straight exhaust, it will already be there.
To Rear composite spring heat shield
