1975 c3
Old Sep 30, 2019 | 11:40 PM
Rayslivensky's Avatar
Rayslivensky
2nd Gear
Default 1975 c3
Just purchased a 75. What ways can you adjust the doors for the gap.
Old Oct 1, 2019 | 08:04 AM
WARVETT's Avatar
WARVETT
There are adjustments by shimming the hinges. Also check that the hinge bolt bushings are in good shape, they might be bad or missing causing the door to sag. I also found that when I replaced my body mounts and repaired the frame the doors lined up much better without adjusting the hinges.
Old Oct 1, 2019 | 01:54 PM
Rayslivensky
2nd Gear
The frame and birdcage as been restored. Could it be possible that some body mounts got mixed up and put in the wrong place. The front door gap appears to be good while the rear over laps the quarter panel by approx 1/ 8 inch. I can post some photos this weekend.
Old Oct 1, 2019 | 08:05 PM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Open your door and try to lift the rear of the door ,if it has a lot of movement your hinge bushes are shot
Old Oct 1, 2019 | 09:22 PM
WARVETT's Avatar
WARVETT
The mounts could be shimmed wrong, but I would check the hinges
Old Oct 19, 2019 | 02:26 PM
Sayfoo's Avatar
Sayfoo
I don't think I've ever had plugs wear out in 2k miles. But, 2k miles in 3 yrs could be a lot of short trips which could build up deposits.
I would pull them and clean/gap them. Should take 1hr+.
To 1975 c3
