Installing a Hydroboost brake system on a 74 corvette. The instructions that come with it show how to route the hoses using a power assist steering box, which obviously the corvette does not have, Any one have a diagram or pics on how it is installed using the unique C3 corvette power steering parts?
Thanks!
Mine is really simple, plumbing wise, one line from pump to HB, HB has a pressure line to the steering, AND a return line to the pump tank/reserve, and that is where I put the T in the return line.....should work fine with a stock pump and steering box.....
but I have a serp drive so my reserve tank is a plastic one mounted on the frame under the m/cyl......I also have rack steering, but that's not an issue, same plumbing.....
When you say to steering you mean to the control valve?
[QUOTE=chstitans42;1600294747]Installing a Hydroboost brake system on a 74 corvette. The instructions that come with it show how to route the hoses using a power assist steering box, which obviously the corvette does not have, Any one have a diagram or pics on how it is installed using the unique C3 corvette power steering parts?
Thanks![/QUOTE http://corvettec3.ca/hydro.htm
