O Ring Calipers
Old Oct 17, 2019 | 09:02 AM
eddp's Avatar
eddp
Default O Ring Calipers
I recently swapped all four calipers. I took advice of some "experts" who said lip seals would be fine if driven regularly and pumped a couple times a month during storage. Well, two of the four have been leaking a bit.
Company has sent four O Ring calipers to replace the lip seals, which I think is very good of them to do.
Here's the question: When I store the car in a few weeks, will I have to pump the brakes to exercise the O Rings regularly, or will they be ok for a couple of months in storage? I store the car in my home that is 75 miles from the home I live in during the winter and only get to a couple times during the winter.
Old Oct 17, 2019 | 11:22 AM
c3_dk's Avatar
c3_dk
Had o-rings for 10 years, they never fail, also after a winter here in Denmark. I never pumpe the breaks.
Old Oct 17, 2019 | 11:45 AM
gjohnson's Avatar
gjohnson
I've had O-ring for 6 yrs , no leaks and it sits 4-5 mo. for winter.
Old Oct 17, 2019 | 02:34 PM
Haggisbash's Avatar
Haggisbash
Lip seals since 2012 and no issues with leaks other than when I tried to use a vac pump to bleed brakes.
Old Oct 17, 2019 | 02:43 PM
revitup's Avatar
revitup
Lip seals for 24 years, never touched the car during winter storage, never a leak.
Old Oct 18, 2019 | 11:00 PM
7t9l82's Avatar
7t9l82
O rings ,9 years no issue.
Old Oct 19, 2019 | 07:48 AM
terrys6t8roadster's Avatar
terrys6t8roadster
O-rings here, did the upgrade 15+ years ago, took off and put on shelf for a few years after replacing them with Wilwoods. Gave them to a friend, he has had them for about 5 years with no problem. T
Old Oct 19, 2019 | 08:26 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Lip seals lock up all 4's. Why would I want to switch to 'O' rings?
Old Oct 19, 2019 | 01:21 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Having rebuilt both, the o-ring setup is more idiot proof. Lip seals simply require more care when putting the piston into the bore. Once assembled correctly, both work fine.
To answer the OPs question, I think you’ll be fine in not excersising them monthly.
To O Ring Calipers
