Alternator keeps failing
Old Oct 26, 2019 | 11:26 PM
  #41
7T1vette's Avatar
7T1vette
Dang good question....
But, again, all that points to the fact that the battery is not the primary provider of power to those fans as presently wired. The battery would not 'care' about some inductive kickback. Just because the battery is "connected" to the same power line, it doesn't mean that the behavior of the current flow will be the same as if the fan wiring was closer to the battery. In this scenario, the resistances IN the wiring are important.
Old Oct 27, 2019 | 10:36 AM
  #42
Richard454's Avatar
Richard454
DC electricity is as slow as molasses compared to the speed of light- IIRC up to about 600 miles per second...versus 186000 miles per second.
So yep- the closer to the battery the better.
Old Oct 27, 2019 | 11:53 AM
  #43
lionelhutz's Avatar
lionelhutz
DC motor becomes a generator and generates about the same voltage as what was applied when power gets cut. Then it decays as the speed slows down.
Old Oct 27, 2019 | 12:21 PM
  #44
GettnBetter's Avatar
GettnBetter
I had a similar problem in my 81. I went through about 6 alternators before the oriley said no more, something else is wrong.
Turns out the problem was really simple. By chance, I noticed the key buzzer was abnormally hot and of course it wasn't working. Seems like it got stuck in a permabuzz.
I just yanked the buzzer from the fuse area the problem has never returned.
I considered replacing it but if it happened once, it's gonna happen again.
Old Oct 27, 2019 | 07:29 PM
  #45
Big2Bird's Avatar
Big2Bird
81's like to eat alternators and A/C compressors. It also likes to swallow ram bushings on steering, and hoses now and then.
Last trip to Death Valley I smoked an SI. Maybe number 6?
Now I use a direct fit AD130? Power Master.
No issues running Route 66 to Chicago and beyond or PCH to Oregon and back.
Old Nov 21, 2019 | 01:04 PM
  #46
edusmc1's Avatar
edusmc1
Thanks for information, helps me a lot.
