Removing Center Console Vent control knobs
Old Oct 22, 2019 | 05:49 PM
pltmgr's Avatar
pltmgr
Default Removing Center Console Vent control *****
1971 non air. The allen set screw on the first came out easily. The second allen screw is rounded on the inside and the allen wrench merely spins. It s at a downward angle so I can't get any kind of extractor or drill on it. I'm concerned about bending/breaking something if I try to force it off. Suggestions? thanks
Old Oct 22, 2019 | 06:06 PM
Mooser's Avatar
Mooser
Try a T8 torx driver (T7 might be too small if it's stripped), might bite into whats left of the hex. You might also be able to grind down a small flat screwdriver to grab
Absolute worse case is to sacrifice the plastic **** by cutting away the back of it
M
Old Oct 22, 2019 | 06:44 PM
ignatz's Avatar
ignatz
You could also try some Loctite, or better, epoxy! Just make sure you will be able to turn the wrench when things set up
Old Oct 22, 2019 | 08:02 PM
Peterbuilt's Avatar
Peterbuilt
Default Just curious
It ain't broke so whey fix it?
Why do you want to remove it?
Old Oct 22, 2019 | 09:27 PM
pltmgr's Avatar
pltmgr
repair heater control
Old Oct 23, 2019 | 11:38 AM
20mercury's Avatar
20mercury
As a last resort, I would drill out the set screw or just cut the vent **** and buy another.
And another thought, I filed down a larger hex wrench size to fit the set screw, now my custom speciality tool, ha. You might try the same routine and get enough bite to remove it. PB blaster would help too.
And one more, heat the **** with a hair dryer and see if that will break the seal when you find or make something to turn the set screw with.
Hope this helps.
Old Oct 23, 2019 | 01:57 PM
7T1vette's Avatar
7T1vette
I agree with putting a bit of JB Weld [stick/putty] epoxy on the end of the allen wrench and leaving it in place for 24 hours. Just make sure that you don't get excess epoxy on the exiting screw threads. You will likely have to hold the Allen wrench in position while it sets up....either manually or with a piece of [light duty] tape. {If you use duct tape, you won't be able to remove it without damaging the epoxy joint in the set screw.} When you attempt to remove the set screw, start with very light torque and gradually add more load to it until: 1) the screw comes loose; or 2) the epoxy breaks and you need to go to Plan B. Also, be very careful that you ONLY twist the allen wrench around its axis. If you put any significant bending moment on the wrench, it could easily break the epoxy joint.
If the screw comes loose, replace the set screw...but you can clean up the allen wrench with a wire brush, once you pull the old set screw off.
Old Oct 23, 2019 | 05:53 PM
pltmgr's Avatar
pltmgr
Melted the **** with a soldering iron. Came right off. In my 50 years of the Corvette hobby I believe this was the most robust piece I have ever dealt with.
To Removing Center Console Vent control knobs
