Drain plug
Old Nov 3, 2019 | 08:41 AM
stingr69's Avatar
stingr69
I had a Muncie with oil drain added by previous owner. He drilled a small hole in the low part of the bottom at an angle and tapped it for a small pipe plug. It does not need to be as big as the factory fill plug. Worked OK but you need to be careful not to over tighten it.
Old Nov 4, 2019 | 06:56 PM
kodpkd's Avatar
kodpkd
Done.... I drilled and tapped a 1/2 NPT drain plug in my trans case. I left the case full of oil when I drill through the case. I used thick grease on the drill and tap to catch the drill shavings. After tapping I flushed a quart of ATF through the case. Then I flushed it with 2 quarts cheap 75W- 85 gear oil. I could fit my finger into the drain hole and pull out more shavings. Installed my new drain plug. Filled with Sta-lube GL4 Hypoid gear oil. It does seem to shift smoother. I hope I got all the shavings. I guess if I am driving and it locks up I will know I goofed.
Old Nov 4, 2019 | 08:25 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
The aluminum wont make it lock up, but if they gummed up the synchros shifting my grind. You'll be okay
