Steering Misaligned after PS Control Valve Replacement
Old Nov 7, 2019 | 01:29 PM
7T1vette's Avatar
7T1vette
If the P/S control valve is fully assembled and the centering adjustment made, I would not undo everything....IF it is only off one revolution. If more than that, I'd probably 'bite the bullet' so it would be correctly done for the next 40 years. [There is a limit to my madness....]
Old Nov 10, 2019 | 07:34 AM
derekderek's Avatar
derekderek
quicky toe adjust after messing with tie rods. at least it will get it good enough to get to alignment shop. you want 1/4 inch shorter measurement in front than in back of the tire.
Old Nov 10, 2019 | 09:05 PM
7T1vette's Avatar
7T1vette
1/4" is a bit much. You want some toe-IN, but about an 1/8" +/- 1/16". That will keep your tires running straight.
