Brake light dim on one side
i verified the bulb is good. 75 coupe with standard lights. It does look like bubba was in there because the plastic bulb socket has tape around it.
any ideas where I should start looking?
thanks
Secure a wire to a good ground and touch the other end to the brass part and post back the results.
Back at the ranch, I confirmed the following.
Both tail lights were burning fine.
Both rear hazard lights were flashing brightly.
Both rear directional signal lights were flashing perfectly.
However, the right rear brake light was very dim, almost no light.
The left brake light was nice and bright.
Thank you all.
1979 L82 M21 FE7
Classic White / Doeskin
