installing temp sensor
Old Nov 7, 2019 | 11:52 AM
titanle's Avatar
titanle
Default installing temp sensor
Hey guys
Im thinking of tackling some winter projects and wanted to know if there's an exact procedure to follow to connect a temp gauge? The old sensor is plugged into my new rpm air gap but its not connected to anything. Previously in the torker intake the mechanic was saying that it was giving incorrect readings so I went and bought a new sensor. How would I go about connecting it to the temp gauge?
Old Nov 8, 2019 | 12:02 PM
suprspooky's Avatar
suprspooky
Originally Posted by titanle
Hey guys
The Chev. Sensors and Gauges are pairs based on Model Year (I can't tell you what years use which Sensor), the best way to determine if the Sensor/Gauge are working correctly is to put the Sensor in boiling Water. You'll need to add a ground wire to the body of the Sensor (unless it's a two wire Sensor) as the older stock Sensors ground via the body threads. I had to move my sensor (BB with AFR Heads) to the water passage on the Manifold and it seems to be accurate (I have a second Sensor for electric Fan control and it's turning Fan on/off correctly within the Range the Factory Gauge is indicating). As far as on Car hookup the AIM has a Wiring Diagram, one of the Forum Members has PDF versions of most years AIM.
Old Nov 8, 2019 | 12:13 PM
MelWff's Avatar
MelWff
On a 1968 Corvette, that's what your profile says, the sender would be in the drivers side cylinder head between cylinders 1 and 3. The wire going to the factory temperature gauge would be there maybe part of the same harness going to the alternator,
Old Nov 9, 2019 | 05:35 PM
carriljc's Avatar
carriljc
Didn't you already ask about this? Just order the temp gauge adjuster from Willcox. You connect it the same as stock. Dial it in.
Old Nov 10, 2019 | 10:01 AM
titanle's Avatar
titanle
Yes I did but what I meant this time is where’s the actual wire that connects to the sensor from the harness. I couldn’t find any extra wire that goes to the sensor
Old Nov 10, 2019 | 12:41 PM
MelWff's Avatar
MelWff
You have to clarify what year the car is and what engine it had from the factory, your profile states 1968, so as I stated in post #3 above the factory wire was on the drivers side connecting to a sender located on the cylinder head.
Old Nov 10, 2019 | 12:57 PM
titanle's Avatar
titanle
Yes it is a 68 with a 350 and initially I do recall the sensor being somewhere on the driver side and the wire went to a cluster near that black square box mounted on the side.
since then the car has new heads and intake so now it’s on the front of the rpm air gap but I can’t seem to find the factory wire that should connect to it
Old Nov 10, 2019 | 01:00 PM
MelWff's Avatar
MelWff
Why would the factory wire have moved from it's original location?
Did you look at the wire harness in the area of the alternator on the drivers side?
Old Nov 10, 2019 | 01:18 PM
carriljc's Avatar
carriljc
It's a DARK GREEN lead. The sensor is grounded to the block. It is a single connector on the green lead and plugs right onto the temp sensor electrical end.
See below:
Old Nov 10, 2019 | 02:53 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
It should have a cloth protective sleave over the wire and look at he wires going to the alternator, Mine is bunched in with those wires.
Old Nov 11, 2019 | 07:01 AM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
68, 350? Isn’t it a 327 and the temp sensor is up on the manifold,I think.
Old Nov 11, 2019 | 11:58 AM
MelWff's Avatar
MelWff
Default Sender location
Look at the picture in this link of a 68 engine, you can see the green wire going to the cylinder head
https://www.corvetteforum.com/forums...ve-covers.html
Old Nov 14, 2019 | 10:10 AM
titanle's Avatar
titanle
Thanks for the help guys!
To installing temp sensor
