First drive
Old Nov 18, 2019 | 10:52 AM
Steve Kistler's Avatar
Steve Kistler
Default First drive
I am hoping that the parts I need will be here shortly. I will try to seat the rings as soon as the parts get here. I appreciate all the information you have made available to me. Since I need vacuum for my brakes to work properly can you advise on what Has to be hooked up for first drive. Thanks
Old Nov 18, 2019 | 09:04 PM
TimAT's Avatar
TimAT
PCV and brakes. Vacuum for the brakes comes off at the rear center of the carb. PCV can come from a fitting in the manifold, usually over the runner for 6-8 cylinders. Some have a nipple on the front of the carb.
Old Nov 19, 2019 | 10:29 AM
Steve Kistler
Thanks. Does it matter if you’re pulling vacuum off the carburetor or from the manifold? Just curious thinking ahead. I also need to know about the vacuum line to the transmission as to what it does (down shifts?) and where to pull vacuum from.
Old Nov 19, 2019 | 11:02 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Doesn't matter. Intake manifold pressure is the same.
To First drive
