Remote starter switch setup?
Old Nov 22, 2019 | 04:53 PM
WA 2 FST's Avatar
WA 2 FST
Default Remote starter switch setup?
Since purchasing this '71 BB with a solid roller valvetrain, I plan on checking the valve lash sometime over the winter/early spring.
On newer cars I've always used a remote start switch tool ... using power and also finding a post on the starter solenoid, often found under the hood. It's easier than using the ignition to bump the starter/turn the engine.
I'm new (again) to the C3 and don't know the best way to do this... I'm assuming the starter solenoid is at the starter itself down by the block; probably not impossible to fish up through into the engine compartment, but if there is a power lead somewhere under hood, that would be helpful. Understand... I'm not actually trying to start the car, just bump the starter remotely to turn the engine over a bit at a time in order to check/set the valves.
Any assistance from those who have done this would be appreciated... or, if I'm missing another very obvious way to easily turn over the engine (crank by hand with a breaker bar is always an option, too), let me know.
Old Nov 22, 2019 | 05:12 PM
MelWff's Avatar
MelWff
You are correct that the switch has to be connected to the solenoid which is on the starter. On my SB, i pull the plugs and turn the engine over by hand with a socket and ratchet.
Old Nov 22, 2019 | 05:16 PM
WA 2 FST's Avatar
WA 2 FST
That may indeed be easier. Nothing wrong with swapping plugs (might as well if I pull them, at least this time, since it will be my first to check them) while I'm working under the hood anyway doing maintenance. Thanks for the advice.
Old Nov 22, 2019 | 05:23 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Both the power and starter solenoid feed are down by the starter. A switch will work, but you will have to jack the car up to connect it at the starter.
You could just run a wire from the solenoid up into the engine bay and then get power from the horn relay.
Old Nov 22, 2019 | 05:52 PM
Richard454's Avatar
Richard454
This is what you need-
https://www.summitracing.com/parts/wmr-w80586/overview/
Old Nov 22, 2019 | 06:03 PM
Big2Bird's Avatar
Big2Bird
TimAT found a trick way to mount a button under the hood on his. I'd do that. handy.
Old Nov 22, 2019 | 06:49 PM
WA 2 FST's Avatar
WA 2 FST
Hey Richard... yes, I have one of those. I haven't used it in a few years, but its in my toolbox. I was just hoping the C3 might have an underhood solenoid or starter relay that I could hook up to, so I didn't have to get under the car and connect directly to the starter. :P
Originally Posted by Richard454
Old Nov 22, 2019 | 08:16 PM
Richard454's Avatar
Richard454
I don't know which is tougher...under the car or under the dash?
You could hit the purple wire at the clutch safety switch - if you can fit your hands under the dash!!!
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
My mechanic friend uses a 2 foot long metal push-finger clamp. The kind with the three little extending fingers on the end. Clips that to the starter solenoid from above up by the valve cover. Then connects the switch above to that. No crawling under the car!
Old Nov 24, 2019 | 01:19 PM
stingr69's Avatar
stingr69
I have added a starter relay and it makes it very easy to hook up the remote switch like Richard posted. The starter works better when hot as a bonus.
Old Nov 24, 2019 | 07:22 PM
TimAT's Avatar
TimAT
IF you car is an automatic, go under the dash to the clutch safety switch. Connect a 10ga wire from there to out under the hood. When you connect your remote switch to that and a 12v source you're done. If it's a manual trans car, that same wire is in the harness under the console. 10 ga, Purple with a white stripe.
Old Nov 24, 2019 | 09:53 PM
WA 2 FST's Avatar
WA 2 FST
Thank you! When the time comes, I will try this... this is what I'm looking for... although it will take a very long lead off my remote starter to get to work, this would be nice to do vs. cranking it by hand.
To Remote starter switch setup?
