Aluminum Intake Worth It?
Say what you will......but it is and always will be a pretty terrible piece.......just comparing it next to a 2101 will confirm that.
Over the years...several magazines did several step by step write ups on the Targetmaster/Goodwrench 350 (Which is almost exactly like an L-48) and always have seen 20hp gains with a real intake manifold....even with a stock cam.......now you are set for when you DO want to add a camshaft.....
The real story is how the headers and intake work together.......they boost torque production immensely down low.......this translates into power you can feel in the seat.
I did this to a 76 L-48 a few years back.......the headers, intake and timing transformed the car.......it would not even spin them from a dead stop before but it certainly would after......
Add a 30 lb. weight reduction, EGR delete, heat riser delete and overall making everything cleaner looking.......it is one of the first mods I believe should be done to an old Carter era Vette.
Jebby
I have personally converted in prior years on other cars, 2 Performer manifolds, on two different GM 350 motors, as the only change and would not do it, ever again, since the benefit was barely noticeable as a manifold only change......sorry but i just don't feel the effort is worth the work for performance. Now for a weight savings? YES!
So lets throw out everything above 4000 RPM, things like high flowing intake manifolds. Which is what he is asking about. Will an aluminum intake make a difference?
@ and below 4000 RPM with 882 heads and a very small cam intake manifold flow is almost irrelevant other than a dual plane is desirable for the low RPM operating range of the engine.
As far as headers go with OP's description it sounds like shorties with a max of 1 5/8" diameter, maybe even 1 1/2" diameter may be most relevant. This is not what I would use or would commonly suggest, but due to his situation it may be the most applicable. Some reading on that subject for the OP
https://www.centuryperformance.com/e...nd-length.html
https://www.hotrod.com/articles/ccrp...er-and-torque/
All things considered I would only go with a higher stall converter IF I didn't change the rear gear and only if an additional cooler is installed as the converter will spend much of it's time below stall speed making LOTS of heat in the transmission fluid.
On my 77 L-48 I first put on the side pipes re-jetted the carb for that and got a noticeable difference in performance.
Then I re-curved the HEI and advanced the static timing, again a noticeable difference.
then installed a 2400 stall torque converter along with a TH350 with a shift kit, another noticeable difference.
Finally rebuilt the carb with Cliff Ruggle's book. Noticeable difference.
Never did replace the intake manifold when the engine was stock, as I did not see it as a restriction to flow that was greater than that of the heads and cam in stock form.
I first did a 0 to 60 when I got it in stock form minus the air pump. 10.9 seconds This is @ 4500 ft not sea level, so some loss of power there.
edit: just read that the L-48 was advertised as zero to 60 in 8.7 seconds, HaHa sure...maybe.
https://www.zeroto60times.com/vehicl...-60-mph-times/
Each mod I made incrementally made it better ending up @ 9.6 seconds, 0 to 60 under similar conditions. Not a massive difference but sure was noticeable.
The tires could now spin and even chirp in a 1st to 2nd shift.
I see what Jebby is saying and normally would agree, but I'm not convinced that in this particular case it applies like most of the scenarios that we come across.
In fact, please read this article on a built 500 gross HP SBC.......
https://www.hotrod.com/articles/dual...d-comparisons/
Look at the facts and read carefully...facts matter.....most low rise intakes will give you 5-7 more gross HP/TQ which you will not feel ....
"We have to acknowledge how amazingly tight this field is in terms of peak torque. How close? It is fair to say that it would be difficult to feel the difference of 2 percent of power. That’s 10 lb-ft of torque, the difference between the Third Place Edelbrock EPS manifold at 506 lb-ft and the Professional Products Crosswind (52026), which placed 20th"
Headers, 2.5 exhaust, and timing is where the power is for a stock motor...an intake will do little to nothing over the stock L-48 cast iron manifold....
I think I'll stick with the stock intake until at some time in the future, I may rebuild the engine and go to aluminium heads.
Thanks.
Thanks.
There isn’t any.....
I think if you were removing the intake to swap gaskets that it would be nothing to pop $125 for an intake.....but it is your engine.
Flatout.....after 30 years of experience building small blocks and working on Vette’s.....I would not do the gasket job without installing a new intake.....it really is that terrible.....and then it is there for later upgrades....not to mention looks, weight and EGR delete.....
Jebby
Jebby
It is like GM just made a two barrel manifold into a four barrel.
Jebby
This typical, stock two-plane intake for a small-block Chevy utilizes a Quadra Jet carb. These feature small primary barrels and large secondaries. Because little attention was paid to port routing, the airflow on these intakes is very poor.
The routing of the runners for a twoplane intake can be seen here. The numbers in the ends of the runners are the typical flow numbers for a stock intake. After a week or so, porting the flow figures posted outside the runners was achieved. Although substantial gains were seen, these still fell way short of a highly developed modern two-plane.
https://musclecardiy.com/wp-content/...016/05/152.jpg
FWIW, Brzezinski says he flow tested some 150 different OE unported GM sbc Iron intakes and All runners flowed between 160-165 cfm. ...
...Elsewhere I found where E 7501 RPM Air Gap unported runners flowed average 216 cfm.
Regardless, I'm with hdeyong and his application his approach
The aluminum 14014432 intake was stock for 1980 and part of the 250 lb weight savings from that year, but requires an electronic choke.
At a more realistic 80% VE it's only around 324 CFM. So where is the air demand from the engine that a better intake needs to supply?
Sure if I could pick up a really cheap used compatible intake made of aluminum and I was taking off the intake anyhow I would probably replace it. But I suspect that cheap GM parts may be somewhat rare in France.
At a more realistic 80% ve it's only around 324 cfm. So where is the air demand from the engine that a better intake needs to supply?
Sure if i could pick up a really cheap used compatible intake made of aluminum and i was taking off the intake anyhow i would probably replace it. but i suspect that cheap gm parts may be somewhat rare in france.
Results:
My 78 L-82 all stock with L-82 intake, stock heads, 2.5 inch dual exhaust...weak compression #6 cylinder: 233 RWHP
78 L-82 with stock Heads, aftermarket cam with more lift than L-82 cam, 2.5 magnaflow exhaust, AND PERFORMER RPM: 248 RWHP
Difference 15 RWHP.......both engines were revved to 6,000 RPM.
So let's think about this difference of 15 HP on the car with better compression, better magnaflow exhaust, aftermarket cam with more lift and slightly more duration AND a PERFORMER RPM intake?
Based on comments previously, documented articles, real world experience, and the results above^^^^who wants to bet the farm on the Edelbrock Performer RPM intake was responsible for the 15 HP gain?
The smart money would be on the cam and the exhaust....I certainly would not bet on the Edelbrock Performer RPM (guess and real world results, at best, 8-10 HP over stock intake, maybe, on a moderately built engine) and double negative for a regular Performer (5-7 HP).......which is very similar to the GM L-82 aluminum intake
ReelaV8R is correct that on a stock engine with STOCK heads, the intake is certainly irrelevant even when revved to 6,000 RPM. On My roller cammed 355 with AFR heads, my builder who has a mustang dyno in his shop clearly articulated that below 6,000 RPM based on his thousands of dyno pulls the regular Performer absolutely would be a waste of time versus my ported L-82 intake. Above 5,500 RPM, The performer RPM would give, on a good day, 10 HP which you would not feel on a 425+ Gross HP motor......
If I was going to ever replace my ported L-82 intake, I would hands down go with the GM Performance ZZ4 intake over the Edelbrock Performer/Performer RPM...any day....The GM performance ZZ4 is a better intake than both edelbrocks
I suppose the manifold might help some, but the exhaust changes are much more important on that car.
