Why are you doing this to a simple-minded question? NO - an intake will not give you a lot of horsepower - but if you have an 'adder' that forces air into it - well then, there you have it, you have something! The skinny answer to all this dialogue - Increase air "in" (a good intake manifold) - a camshaft to hold the valve open as well as close it at an optimum time and ramp, use a valve sized to flow the additional volume, and an exhaust manifold (headers) to expel the spent exhaust in such a way that the pulses scavenge one another and force the spent air out...Optimizing those pulses in a tuned way - that will net seat-of the pants power! GOLDEN BUZZER - Fuel, Intake air, valve lift and duration (as well as cylinder size and combustion chamber) combined with many other elements net real-feel gains! Its a combination and they should be addressed in a package sort of way - there are plenty of members that can offer packages that will net REAL Gains ........... no rabbit holes please - don't confuse this member - let's keep it simple - please...
Right. The thing that's coming up regularly is horsepower, but I'm after torque and reasonable mileage. I lived in Canada for over 50 years, and in the US for about 3 years, (SC, NM and DC). I miss those long straight roads at times, but it is what it is. Here, where I am, it's curves and hills, which are fun, which is why I got a Corvette. The locals thrash their teeny motors and stir gearshifts like they were making pudding, and that's not for me. A V8 automatic that pulls fairly strong at lower RPM and doesn't gulp gas that costs well over US$6 per gallon is the goal. So, the dual exhaust, new distributor, and "H" pipe kit I've got ordered and on the way, (good old Fedex), will help the cause.
Sure, we have big expressways, but who wants to sit on them?
It's fairly likely I'll rebuild the engine next year, and if I do, it will be set up, from top to bottom, for bottom end torque and decent mileage. Maybe even a 383, because I can use the same block.
When my parts show up and I get them installed and set up properly, I'll post the results.
Thanks everybody.
Clearly we disagree which is fine but others certainly don't agree either that a aftermarket manifold ALONE will noticeably increase TQ/HP on built SBC, much less a stock base motor and the documentation does not support that claim either. I would like to see a Performer 2101 alone adding 20 HP to any engine? You stated combined with everything else a manifold change adds 20 HP. I dynoed 233 RWHP (Factory L-82 220 NET HP) with my stock L-82 with no emissions, shorty headers, 2.5 duals, Stock L-82 aluminum intake, stock 882 emissions cylinder heads, stock L-82 cam with a weak compression #6 cylinder.......in my case, the increase had nothing to do with the stock L-82 intake......100% all in the exhaust alone......
I have personally converted in prior years on other cars, 2 Performer manifolds, on two different GM 350 motors, as the only change and would not do it, ever again, since the benefit was barely noticeable as a manifold only change......sorry but i just don't feel the effort is worth the work for performance. Now for a weight savings? YES!
And it would have made more power with a better intake. And your car would make more power now with a better intake.if you want a stock look paint it blue. You paid big for a good set of heads and you choke it up.you even went to a Holley carb long ago who cares if a 78 or 79 is ncrs correct ? My gosh you have aftermarket wheels.stop living in the past lol
I bet an rpm or weiand air strike would make anoticeable difference against the alum copy of a stock iron Q jet intake.
You can port match or mess with the plenum doesnt really do much on stock stuff.
