hybertech?
The Hypertech chip will not change air/fuel ratio. A modified engine does not need a different air/fuel ratio than any other engine, but it will need higher flowing injectors and a good fuel system which will maintain fuel pressure at WOT in the 14 psi range. You otherwise stand a chance of leaning out at WOT - not due to the ECM chip, but due to the flow limitations of the stock injectors and pump. The Hypertech chip changes the cooling fan "on" temperature to keep engine temps a little lower, and it advances the timing a little with a more aggressive timing curve. That's it.
Lars
The Hypertech chip will not change air/fuel ratio. A modified engine does not need a different air/fuel ratio than any other engine. The Hypertech chip changes the cooling fan "on" temperature to keep engine temps a little lower, and it advances the timing a little with a more aggressive timing curve. That's it.
Lars
The best thing to do really is to purchase my new Rev "D" HAM Board and then have Dynamic EFI install it into a 1227747 ECM with the EBL Flash II and start tuning for performance. You will have everything you need to make it haul A** and then some. Oh, and the stock injectors WILL NOT WORK to make the HP you want, go either 80 or 90s. I would also go with a 2.0" TB bore and external FP regulator. Hope this helps. If not, PM me and I will send my number and we can talk.
Lars
The hypertech chip has a significant positive effect on the 82/84 700-R4's "shift quality" which your above note implies is incidental. ("Only...." "That's It".). But, it basically fixes the primary causal issue. Immediately, at that. As I believe you know (as I do from talking to Dave McLellan, the `82 Corvette Chief Program engineer at a June club event, and being an OEM rep for years, daily interfacing with customers and my Dealer's Techs), The native eprom is programmed to maximize fuel economy by locking up the trans in a higher gear at the lowest possible RPM - causing harshness, lugging and the is fully connected to shift quality. It does improve fuel economy by essentially locking in a lower RPM, but gawd, it lugs - gets old after several thousand miles - and, it was one of GM's top reasons for customer assistance requests (CARs) being opened by upset 1982 owners (followed closely by cost of ownership due to brake repairs). The premature lock-up point causes NVH issues (especially H) during the down-shifting process (and, some on the upshift as it unlocks) which is noticeable and equally important to shift quality/feel/experience. The Hypertech did their homework/testing and the chip significantly enhances it virtually without tradeoff. The primitive native chip is obviously not dealer-programmable, and while GM knew exactly how to fix it they could not legally provide an alternative to their irate C3/C4 owners without having the entire system recalibrated and recertified by the EPA - and Dave McClellan said they barely squeaked by with their `82 corporate avg. fuel economy mandate in the 11th hour.
I just want to be clear that my recommendation is first hand and researched - as you stated the eprom does not control the 700-R4's shift points as modern transmissions have in recent decades, but the Hypertech chip is the transmission performance upgrade that GM would have released if legally possible.
DV
But back to the actual question: The Hypertech chip will have no effect on the OP's air/fuel ratio.
Lars
