Question on Sagging Trailing Arm...
The TA front bushing bolts are shimmed and then tightened at ride height so the bushing isn’t torn up from being extended too much one way or the other. Your pass side arm is staying up because it was tightened at ride height and the bushing is holding onto it.
Your shim on the pass side is just too long ... seen it before . Whomever aligned / shimmed it should have trimmed it to fit in the pocket and be held down by the cotter pin.
Your frame looks clean to me I don’t see rot or cracks in the later pics you posted.
Your drivers side bushing material may have let go inside or the shims and bolt are just looser in that side and able to pivot with the TA as it travels.
If your tires wear well and your rear isnt squirrelly then your ok...
The sleeve inside the bushing is supposed to have serrated ends, so that when you tighten the front trailing-arm bolt at ride-height, the serrations bite into the side of the trailing-arm pocket and provide resistence whenever the trailing-arm moves up or down from ride-height.
If that arm was tightened at anything other than ride-height, it will cause the rubber bushing to torque against the metal sleeve constantly, and the metal sleeve can separate from the bushing, giving no resistance so your trailing-arm will drop down like that.
It is also possible that the nut for that front pivot bolt wasn't tightened enough, and those serrations acted like a saw-blade, wearing a groove in the trailing-arm pocket/shims so that metal sleeve can rotate.
None of these is optimal, but none is fatal either. After you've installed everything you're putting on the rear suspension, loosen the pivot-bolt, get those shims locked in with the big cotter-pin, get the car at ride, then tighten down the pivot-bolts to spec.
TA bushings do not have serrations and they wouldn't work anyway because the shims are right up against the bushing washers (not the pockets) to enable setting the toe for the rear.
Still, even without the serrations, it wouldn't be designed to pivot freely on the bolt, but to be firmly held in place and the deflection ordinarily taken up by the bushing.
1. As all can see in my pictures, when removing the half shafts, are they supposed to go in at the exact position they came out? I guess what Im asking is do I need to mark anything? Or am I just taking them out and popping new ones in? Since each side is not lined up, I wasnt sure. But it seems Ive seen or read somewhere that the exact position has to be right on target with how it was before.
2. Secondly, is there a proper technique in removing the half shafts. I have the u-joint nuts loose as well as 3 of the 4 bolts that mount to the hub. Having trouble getting to the top side bolt closest to the front of the car...
Just wanna know before going bananas...
Are you replacing the U-joints, and rebuilding the half-shafts while they are out? I ended up having to cut several U-joint straps, and replacing them, the bolts, and the U-joints. I didn't mark anything. What does the shop manual say?
I don't want to be a downer, but getting the trailing arm pivot bolt out after the nut is off is the hard part. It gets rusted into the inner bushing sleeve and will be free in either side of the frame pocket, but stuck in the inner bushing sleeve. In that case, you will need to pry out the shims on either side and get your saw in there and cut the bolt shank on either side of the arm bushing. I use a cutting torch, takes about 5 seconds, but non professionals should stay from this method due to the potential for a bad outcome.
Good choice on the solid Spicer U-Joints. I had the time to have my half-shafts rebuilt with the trailing arms, but insisted on the Spicers, and I'm very glad I did.
Good luck with the next step! I found that a single carbide sawzall blade did a better job than a half-dozen thin bi-metal blades. Hopefully you don't need this advice, though.
Hope this might help and much thanks to you for posting this and to everyone that offered advice and help.
Happy New Year to All!
Happy New Year!
To make them let go you gotta get a pry bar in between the bushing and frame and lever on it , one side then the other , back and forth , back and forth , back and forth , have a beer , back and forth , you get the idea !!!
Once its hanging on those bolts ,if your super man you can wrestle it to the ground , or get some help (better idea) I have used a trolley jack to take the weight and to roll it out from under the back
BTW don't forget to take the tail shaft off first !
Well that's one way to drop the diff , however I just re- read your post and you just want to replace those two big bushings on the cross member ? If there's no work needed on that diff , honestly I would not bother to change those bushes , for normal driving those things last forever .
My son is doing this same repair but he had to have the Differential rebuilt with all new bearings, stub axles, posi clutches and seals. Check the end play on the stub axles. There are many threads on what to look for when doing this job.
Keep us posted you have a following. You take nice pictures post a couple.
