Question on Sagging Trailing Arm...
Unless your blind, I guess you see the question/concern I have. Obviously the drivers side trailing arm is sitting on the frame. The passengers side is not. Please see close up of each side...
Drivers Side:
Passenger Side:
Prior to getting this far, I snapped a few photos in the event my amnesia kicks in and I forget where certain things went. Prior to removing spring and strut rods, everything looked alright...but surely this isnt right? When I tried to remove the drivers side strut rod, she was in a bind...had to jack up the hub just to take the pressure off to knock the rod out. Now I know why...And to be honest, before I go monkeying around with the trailing arm, I thought I'd drop back, punt and see what some of you more skilled guys have to say. Drive wise, prior to the overhaul, shes all original so I thought after 41 years, she'd like an upgrade. So I'm not sure if anything was off as its always ran the same(suspension wise) for the last 19 years that I've had it? As far as play...you can push up with ease on the drivers side to move the entire trailing arm with ease. Passenger side is pretty stiff but does move with some force...
Before pics...
Any ideas?
Look to the right of the jackstand cradle. Does that frame appear to be coming apart? Looks like the welds are broken. Maybe not.
Anyway, sure like to see you add some extra jackstands forward. Or even some cement blocks. Anything! Just in case of a primary jackstand failure.
That car will crush you.
and there's a lot of weight hanging on that pivot bolt, but for years the shocks kept it from going any farther so it's possibleI'm sure you looked but is there anything in the pocket possibly holding it up?
Try rotating the axle 90 degree and watch to see if the u-joints are binding
M
Most importantly, I apologize for the pics. When looking at them in the pics, the light does cast a shadow(with all the road grime) that the frame may in fact be cracked. So just to clarify, I went out and shot from a different angle with a different light to go ahead and rid that element:
Drivers Side:
Passenger Side(no shadow):
So the kit I ordered from Vansteel was the 78-79 Advanced Street & Slalom Suspension kit as pictured below:
Kit included:63-82 Advanced Street & Slalom Kit
VSD-01A
- 360 lb Compostie Spring
- Smart Struts
- QA1 Front Single, 18 point Adjustable Semi-Coilovers w/550# Springs
- QA1 Rear Single, 18 point Adjustable Shocks
- Spanner Wrench
- 1 1/8" Front Sway Bar
- 3/4" Rear Sway Bar
Also ordered a rear bushing kit from Willcox:
REAR SUSPENSION MOUNTING AND HARDWARE COMBO KIT 78-79
To "71yellow454": So I wasnt planning on replacing the trailing arms...too cost prohibitive! Not to sound like a complete moron, but I'm assuming then that the trailing arm concern is actually in the passenger side? Which would mean its supposed to be sitting on the frame like the drivers side?
To "Mooser": So I see nothing in there, minus the shims of course...But if you look back through the pics, you can see the cotter pins on both sides as well as shims. If you look at the passenger side pics and most recently posted passenger side pic, you can see a shim wedged between the frame and I guess pivot bolt. Wondering if I raise the hub assembly and try turning the shim back towards the front if it will fall down and lay onto the frame? Drivers side shim is not like this...
Even more noticeable in original pic...:
P.S. To All: Extra Stands added
M
And, so the trailing arm is supposed to be resting on the frame then, correct? In other words, the problem is the passenger side, not the drivers as initially thought?
And then a set of ties (up to the frame) to hold the rear up in location when installing the shock etc until it was able to support itself
Not sure exactly where the frame issue is they are pointing out but certainly have a look and see if it's light/shadow or not
M
M
Yea, Im freaking out about this "crack"...I may be totally looking over it but they look the same on both sides and I dont see any cracks...fingers are crossed! If it is cracked, trailing arms will probably be the least of my concern...
Mooser, thank you sir...
Try rotating them 90 degrees to see if the passenger side lowers......
Welded tight on drivers side.
Now I assume a rubber bushed trailing arm would be like that also, but I have not had one of those apart.
Your suspension never droops this much during normal driving.
The long alignment shims are cotter pinned in place and should not move.
I would be concerned about the "loose" one. Maybe the 41 year old bushings are shot.
At any rate I would pull one or both trailing arms and inspect the bushings. At 41 years it's time.
Or at the very least inspect both arms for looseness or movement under pressure. (Big crowbar)
Duh! See post 14. It is usually the obvious!
Perhaps some Kano Kroil will loosen up the shims enough to let you pull them out to replace them with stainless shims (you are doing the trailing arm bushings, right?)
Completely unrelated to your current issue, it looks like the kit from Van Steel comes with their high-arch spring. They also make a low-arch spring, similar to what VB&P used to sell. If it's not to late to contact them and swap (or confirm that you got the low-arch spring), you may save yourself some grief in the future.
