Trailing arm bushing evaluation
Old Dec 29, 2019 | 06:15 PM
Bikespace's Avatar
Bikespace
Originally Posted by Big2Bird
For one bolt? 18V De Walt cordless and 1) 8" LENNOX carbide blade your done 10 minutes.
Or die grind off one end and drift,
Or soak and heat,
Or Blue Flame Wrench.
Or...............
Yup! I burned up several cheap thin "metal" blades on one side. Then a carbide blade finished that one side, and the other, and could do it all again.
Old Dec 30, 2019 | 04:26 AM
DorianC3's Avatar
DorianC3
Lenox Carbide seems to be the way to go. I found some over here on this side of the pond... but they are only available in 9 inches. Do you only have that as well ? I don't think that Lenox makes 8-inch metal carbides...
Old Dec 30, 2019 | 05:44 AM
Big2Bird's Avatar
Big2Bird
I told my wife 8inches. 9 inches it is.
Old Dec 30, 2019 | 09:16 AM
DorianC3's Avatar
DorianC3
Old Jan 9, 2020 | 07:44 AM
DorianC3's Avatar
DorianC3
Just to put a cap on this one... and thank you all for your feedback.
I decided to replace my TA bushings with rubber ones. See here.
The bearings seem in reasonable condition, so I will leave them be for now. I have also decided to rebuild the arms myself. Having priced everything out, it is more cost-efficient to import the tools and do it myself than send to the USA for a rebuild. In fact, just VAT and shipping would more than offset buying the tools.
I must say seeing this fellow at work
http://mycorvetterestoration.com/196...p#.XhceYlVKg3E
...was the tipping point to deciding to DIM.
Old Jan 9, 2020 | 07:47 AM
caskiguy's Avatar
caskiguy
You'll do a fine job. Thanks for the link.
Have fun.
