The Force Awakens...
: one rear brake caliper O-ring conversion kit and a tool to press in and stake the trailing arm bushings.Another non-related part I picked up was a power steering pump restrictor. I like the Borgeson, but it feels over-boosted.
In addition, I purchased a few "luxury" items.
- Floor mats, Dark Blue with 'Stingray' script embroidered. "Stingray" because I think that needs a little more reminder... and Dark Blue, because my Bright Blue carpet is already getting soiled. Getting a set of Bright Blue floor mats would only be more of the same.
- T-cushion. Having driven the car some longer distances, I see now why these are nice to have. (Hm, a cup holder would also have been a good idea.)
- T-top bag. Here again, I am not sure this really is a luxury item. Throwing the T-tops in the back seem like a good way to damage them. I bought the black ones (cheaper) and will spray them Bright Blue since I have the dye.
Stay tuned.
BTW - I was not able to remove the "stake" from the second trailing arms. I was busted down to sawing through the middle. Unfortunately, my new sawzall quit 3/4 of the way through #frustrating
Until I get that bushing out, I can't really start cleaning up the TA.
I was surprised how fast the Dremel cutting wheel got through the steel. It only took me a few minutes with some breaks in between to check progress. I will not be reusing the strut. Heim-joint rods are on order.
Pried it open
Slid the rubber out.
From there it was easy enough to wrench off the strut.
I located the join line of the inner bushing and went lightly over it with the cutting wheel.
After prying that open it loosened up entirely so that it spins around the shock mount. I decided to leave it in there for support when I attempt to knock out the shock mounts. I have read stories about broken off ears. In the meantime I will hit it with WD40 every eve and maybe some heat. I will bFH.e using one of those knocker tools that thread over the end plus a BFH.
Originally I was planning to leave the bearings for another day. Mine seemed to be ok. But then I discovered this:
Best as I can tell, Bubba installed the spindle before the dust shield and plasma cut it in half to put it on.
Yes, I could make this work, but this really flies in the face of all the work I have done up to now. I might as well take everything apart, clean, paint, install new bearings, do it right and be done with it. I took advantage of Willcox's 20% off and ordered new dust shields, bearings and tools.
Once I am finished with this the only thing to do with the rear would be the carrier.
I’m spread thinner than I want on this.On the other hand:
a. It’ll be done and done right
b. I look forward to doing this... mainly having clean dust covers, a parking brake that works, and, well... all of it.
Most important of all: peace of mind.
way of holding the spindle while I use some extended leverage.
Not pretty, but I grabbed whatever I had around.
What was it that Archimedes once said ?
Threads look clean
Looks like someone has done this job not so long ago. This looks récent, though I could not tell you how recent
I saved for one year so Gary, GTR1999, could build my rear differential.
There is someone else who will tell you he can do it cheaper, but "beware", that guy is a liar and a thief.
Check my thread in the Transaction Feedback section on this forum.
Contact Gary and ask him what you need to do this job correctly.
He will talk to you and give you excellent advice even though is isn't earning a penny from you.
FWIW... the shims are marked and ready to be replicated.
If this is the drain hole...
Then all this dust needs to come out ! I will have to drill new hols for the stainless steel shim retaining pins. All of this will get a coat of rust converter/inhibitor.
One of the brackets under the seat broke. So I outsourced it to my neighbor youth. (He’s working on an 80s VW Passat). He practiced his welding skills and did a great job.
